Home Forums Sign Making Discussions Vinyl Vinyl cracking glass?
  • Vinyl cracking glass?
    Posted by Nick Tunstill on 11 September 2012 at 13:11
    I applied some black frosted window vinyl to the bottom inside of a shop window in a strip apporx 2.3 m x 500mm with a silver frosted vinyl same width about 1m high running above it with a gap in between. The window has developed a crack running upwards about a month later and the customer has been told it is down to the dark vinyl and high temperatures by a glazier. The glass is very heavy duty laminated material so very strong. Is this possible?
    Stuart Miller replied 13 years, 1 month ago 8 Members · 8 Replies
  • 8 Replies
  • Gavin Dooley
    11 September 2012 at 13:50
    I’ve been told this can happen by a glazer who’s seen glazed units explode because of tint applied on the inside, the gas between the sheets of glass heats up. Asked him if this can happen with thoughened glass, was told "Yes".
  • Mike Grant
    11 September 2012 at 14:15
    The simple answer is YES!
    Do a search of the boards as this has been discussed at length before.
  • David-Foster-
    11 September 2012 at 16:55
    quote Mike Grant:
    As said before, definitely YES plus being Black it is even more likely. The glass behind the black would be warmer than the rest of the cooler glass causing stress and cracking.
  • Nick Tunstill
    11 September 2012 at 17:00
    Thanks for the info, looks like I will be replacing a window then!
    Shame the suppliers didn’t warn me of this when ordering.
    11 September 2012 at 18:12
    There was some good advice and information posted by Stuart Miller here
    http://www.uksignboards.com/viewtopic.p … ack#414222
  • Nigel Pugh
    11 September 2012 at 20:30
    quote Nick Tunstill:
    Nick I find your comment regarding suppliers does seem harsh, suppliers offer a huge amount of films that you can apply to glass, how you use it or colour combination is down to you and your customer, suppliers can only advise what vinyl’s are suitable, how you use those materials is down to you signmakers.
    Nigel
  • Jason Xuereb
    12 September 2012 at 04:13
    It’s called thermal loading and its covered in the Avery Training Academy under Architectural signage.
  • Stuart Miller
    14 September 2012 at 18:52
    Yes Nick as all the others have said.
    In fact laminated glass is one of the worst offenders.
    I support Nigel in the comment about suppliers. they can not be expected to warn every sale about where not to use their materials. I reckon that is the responsibility of the tradesman to know his trade. Unfortunately this may be an expensive lesson.
    However when I first began window film application my suppliers would not sell me any film until I had undergone training in exactly this scenario as we encounter it with every job. We also fill in a Glass application chart so the supplier can warranty the job.this is usually done before installing the film so the supplier can warn of any adverse affects.
    Its a lot more complicated with signs and vinyl as we do not get absorption figures for each colour. Having two different vinyls on the same pane with different absorption would increase the likelihood of thermal stress.
    Much more info in the thread Phil has referred to.
