Home Forums Printing Discussions Roland Printers Views on the Roland XR-640
  • Views on the Roland XR-640
    Posted by James Boden on 12 June 2017 at 08:35
    Hi Guys,
    May be purchasing a XR-640.
    Just wondered if anyone has some first hand experience with one of these or any opinions to share?
    James Boden replied 8 years, 6 months ago 4 Members · 6 Replies
  • Stafford Cox
    12 June 2017 at 09:17
    I’ve worked on a few of them and they’re pretty good. Proper fast!!
  • David Stevenson
    12 June 2017 at 09:35
    We’ve had a couple of 640’s. 1st was an absolute disaster, was bought brand new and was faulty from day 1. Destroyed a fortunes worth of material. Couldn’t cut accurately even with 40mm of bleed around the text. Finally got it replaced and thankfully the second one was great. Had a few problems with error messages which got resolved when I believe what is known as a new "scan motor" was fitted. Changed it now to a separate printer and cutter which is great as one can print while the other cuts. Allows for an uninterrupted work flow
  • Gary Birch
    12 June 2017 at 15:10
    We have 2. Both serviced annually and have missed a beat.(Touching wood) and would have no issue in recommending them or indeed buying another.
  • James Boden
    12 June 2017 at 15:49
    Thanks for the replies guys.
    Just out of interest Gary, what ink configuration are you running on those? Do you have white & metallic on either?
  • Gary Birch
    13 June 2017 at 07:28
    quote James Boden:
    We started off with one of each but as we didn’t have the call for it the white and metallic just ended up being expensive cleaning cartridges so we just took the decision to stop with both.
  • James Boden
    13 June 2017 at 11:47
    quote Gary Birch:
    quote James Boden:
    Thanks for the reply Gary. This is what I was thinking, don’t have much call for metallic here either. Cheers.
