Home Forums Sign Making Discussions Vinyl Views on 3M Scotchcal 30 Series
  • Views on 3M Scotchcal 30 Series
    Posted by Ian Pople on 2 December 2008 at 13:43
    Please can I have comments from any one who has used this vinyl.
    I am interested in gloss black to be applied to flt surfaces for vans.
    Looking for a cheap vinyl for up to 5 years as this one is under £50 a roll.
    Ian
    Stuart Taylor replied 16 years, 11 months ago 4 Members · 6 Replies
  • David Rogers
    2 December 2008 at 15:18
    What width roll? 600mm?
  • Stuart Taylor
    2 December 2008 at 16:31
    30 Series will be fine for the application you’re looking at, however I should point out that it is a monomeric calendered vinyl and is therefore suitable for flat applications only (which is what you’re stating anyway) – 3M class this as a 5 year durable product, however as with all monomeric vinyls they will be prone to shrinkage over time.
    If you’re worried about this you should consider a polymeric calendered vinyl which will be good for up to 7 years for Black, will be more dimensionally stable, flexible, softer, easier to cut and weed and allow application over slight curves as well as flat areas. Obviously this means the product is more expensive than a monomeric but gives more peace of mind if you’re requiring a longer lifetime out of your graphics.
  • Ian Pople
    2 December 2008 at 17:16
    610 or 1220
    and I have ordered the 3m form you Stuart so I hope it will be fine. The price difference is all most double for the 50 series.
    Thanks for your help.
    Ian
  • Mathew Gibson
    2 December 2008 at 20:19
    Ive just started using william smith and using 50 series and its the best everyday vinyl that ive come across and must say that william smith’s service is second to none!!!
  • Stuart Taylor
    3 December 2008 at 09:27
    quote Ian Pople:
    610 or 1220
    Ian
    Hi Ian
    Thank you for the order – I am sure the 30 series will work fine for you – yes the 50 series is quite a bit more in % terms compared to 30 series but in real terms around 10p per sq ft more expensive, so depending on the size of graphic on the vehicle may only cost a couple of pounds more per vehicle but with more peace of mind.
    Stuart
  • Stuart Taylor
    3 December 2008 at 09:33
    quote Mathew Gibson:
    Hi Mathew
    Thanks for the comments – glad that you’re happy with our service and the 50 series. It is our most popular range in the general signing and vehicle markings sector.
    Stuart
