Very Annoyed! Supplier problems!!
Hi All
Had a job to fit today – load of stand off flat cut letters and arrow shapes in various Dibond colours. Ordered them from a well known supplier and this was my first and probably last order with them.
It was also my first job for this kind of sign and wasn’t sure how long or hard it would be.
Overall size of the job was about 2.5*2.5m, carefully laid out the template onto some hardboard sheets, marked out the the locator positions, drilled them in the sheets (read a tip on UKSB about greater accuracy in making a hardboard template to drill through into the wall – worked really well). Took no time at all and everything lined up spot on.
Got up this morning to lovely blue skies, setting up the scaffold tower took half the normal time and had the hardboard template on the wall a few minutes later. Started drilling the 100+ holes into the wall and these must be the softest bricks I’ve ever come across – half an hour later all female locators on the wall and ready to start ‘snapping’ on the letters and shapes.
I was expecting to be there all day and was feeling rather pleased everything was going so well – I’ll be home by midday at this rate!
So gets the first flat cut and gently pushes it onto the female locators and as soon as I apply any real pressure the shape falls away from the male locators on the back which are supposedly epoxy glued. So I try a second one and then a third and it’s the same on them all.
I then realise the idiots have not removed the film from the back of the Dibond and had glued all the locators onto the film rather than onto the Dibond!
Is it just me or this about the most stupid thing you could imagine from a company that is probably churning out 100’s and 1000’s of trade flat cut stuff each week?
Had to cut the film round each locator with a scalpel, remove all the rest of the film, draw round each locator, lift of the locator and circle of film, then go about properly epoxy glueing all the 100+ locators.
Long shot is it did take all day and I’m seething – I’m tempted to name and shame but I’ll wait to speak to them on Monday first – will let you know what they say. (chat.)
Macky
