Home Forums Printing Discussions Roland Printers versacamm sp300 print drifting
  • versacamm sp300 print drifting
    Posted by Lloyd Morgan on 28 October 2016 at 11:25
    i hope someone can help, my printer has starting drifting it’s print since i did a manual clean, i swabbed around the heads with a cleaning solution, and then the wipers and since then after a while the print will drift out of since, i have checked the clear encoder ribbon for dust or ink splashed and it looks clean. any ideas please?
    a simple print test with the button shows every thing is fine, the problem only happens after a few minutes of printing, it like the carriage is starting from a new place each time.
    thanks for your time i really appreciate it
    Lloyd Morgan replied 9 years, 2 months ago 6 Members · 6 Replies
    28 October 2016 at 11:38
    Check your grit rollers aren’t contaminated with ink. This can cause the vinyl to slip which means the print drifts out
  • Richard Urquhart
    28 October 2016 at 14:30
    Also check the rollers, I’ve had the rubber slip on the wheel and needed new roller wheels
  • Simon Worrall
    28 October 2016 at 18:01
    Clean the encoder strip.
  • Graeme Dingwall
    28 October 2016 at 19:28
    Have you calibrated the encoder strip in the engineers menu
    28 October 2016 at 21:36
    Looks like the encoder strip to me, had the same symptoms with our RS.
    It can be removed and cleaned with cleaning fluid.
  • Lloyd Morgan
    1 November 2016 at 14:23
    thanks for ther replies, it turned out to be the encoder strip, cleaning it didn’t do anything so i turned it upside down and bingo, noticed the flat ribbon cable going to the sensor was slapping about due to ink dust build up so gave that a clean too.
