Home › Forums › Vinyl Cutter Discussions › Roland Cutters › versacamm cutting problem
Posted by Dan Osterbery on 3 June 2011 at 09:35Hi Guys,
i am having a problem cutting certain types of media in my verscamm. I have a 0.50mm offset smart blade in the machine, and some medias it tends to do a pounce style cut. I have tried different cut speeds and different cut pressures and it doesn’t seem to make a difference. I have bought two new roland blade holders and loads of new blades, but it doesn’t seem to help the problem.in the past we had the problem with vinyl and swapping to the smart blade cured the problem. The media we are struggling with is a ttrh t-shirt transfer material
Anybody have any ideas?
thanks
Dan
Lorraine Clinch replied 12 years, 4 months ago 7 Members · 17 Replies -
Hi george,
the holder is black, there is a blue circle at the base and the tip is metal colour?thanks
dan
can post a photo if you think it would help?
curiously have just cut the same material on another of our cutters and it has cut it perfectly, so it is the versacamm that is poorly, not dodgy material!
any suggestions greatly appreciated!
Dan
I sometimes have the problem you have described when cutting TTRH if I print and cut in one operation with a bleed on the artwork. The ink softens the media and it can cause the media to stretch and bunch up before it cuts it, giving it that ‘pounce’ effect.
My solution was to print with crop marks and allow them to dry overnight before cutting. It also helps reduce edge curl doing it this way.
Edit- just saw your recent post – if you are having this problem on unprinted media, maybe the heater on the versacamm is softening the material and causing the problem?
cheers owen,
hadn’t thought about the heaters! will give that a shot and come back!thanks
Dan
Dan, i was advised to use a smart knife with a red tip for cutting transfer material I think it has a different degree blade its 45 i think it certainly worked for me speak to the man at Edward Mathias
http://www.blades.uk.com/moreaboutsmartknives.html
G
George,
you have just become my hero! i pay double that for the blades and have about 10 years of old ones that i can send back and have renewed! thanks mate!will call them about the red tips! (although, i did cut the same material on a different cutter yet with the same blade!)
Owen might be on to a winner about heat!thanks for the contact though, if i ever make it to a uk sign show, I owe you a few beers!! Or if you make it Menorca a few Sangrias!!
Dan
its only tiny! we are sant lluis! near mahon (the airport)
will let you know nearer the time so you can get the beer on chill 😎
no worries! in these temperatures always have loads of beer cooling!!!
you will probably still be on the phone to Edward mathius when George gets there. Great company, but expect a long call
ok update time, turned off the heaters and dryers and it cuts perfectly!!!! Top marks owen! Will try to keep call short and sweet as dont fancy Spain-Uk massive phone bill!!
thanks for your help guys! Very much appreciated
Dan
Whats the different coloured blades? I have a blue one and a red tipped one…. what ones what?
I brought red for cutting flock, not that I ever do.
Blue one for vinyls and printsits all about the angle apparently!
Give Harry a call
http://www.edwardmathias.com/bladeangles.html -
John, as Chris says it’s just a quick way to tell which blade is in the holder, I only have the blue tip holders which are 45 deg blade as I only cut vinyl, the red tipped ones are 60 deg blade for cutting stuff like flock.
Sorry Chris, not quite sure how I missed it but didn’t see the link you added.
Red for flock, and any thicker material, and especially reflective!
