Home Forums Sign Making Discussions Vinyl Urgent advice needed Regarding Removing Contravision Vinyl
  • Urgent advice needed Regarding Removing Contravision Vinyl
    Posted by Glenn Sharp on 11 September 2019 at 07:51
    Hi all
    We’ve been asked to remove some contravision vinyl which was applied around 18 months ago
    It’s the only contravison job we have ever done so we have never had to remove it before
    Only thing is, the customer needs it removing today and I need to work out whether we have the time to do it or not
    Does it remove easily or is it a pain??
    Glenn Sharp replied 6 years, 3 months ago 4 Members · 5 Replies
  • Alex Crosbie
    11 September 2019 at 07:59
    Usually really easy, if it doesn’t peel off then a scraper will get rid of it quick
  • Neil Davey
    11 September 2019 at 08:01
    Ditto Alex – I’ve removed it from flat glass and it comes off ok and yes a bladed window scraper will help. The window will probably need cleaning too to remove any residue.
  • Chris Wilson
    11 September 2019 at 08:07
    We do these all the time for a local theatre. Biggest window/print is 4.5m x 2.3m and we strip and the clean that in about 45 minutes.
  • Glenn Sharp
    11 September 2019 at 08:58
    That’ll do me
    Thanks very much everyone
  • Glenn Sharp
    12 September 2019 at 14:16
    Thank you all for the advice
    A job that I had envisaged taking at least 3 hours was done in an hour
    A very appreciative customer as a result
