Home Forums Software Discussions Corel Software Unusual happenings when saving a file in Corel 11
  • Unusual happenings when saving a file in Corel 11
    Posted by Fran Hollywood on 13 March 2006 at 23:03
    If l create a shape or text in corel, l save the file as a *.plt. If l reopen the file the size of the shape or text has changed, the proportions are the same it’s just that it 2-3% smaller. E.G a saved rectangle would measure 600mm x 173mm when l reopen it might be 591 x 168 Any ideas why this is happening? (?)
    Andy Gorman replied 19 years, 9 months ago 3 Members · 5 Replies
  • Andy Gorman
    13 March 2006 at 23:18
    When you export from corel to plt there are other settings in the export filter that have a bearing. Like plotter units and scale, for example. Have a look around in the export filter options.
    As an example, I used to use a particular program that used corel plt files but I had to export with the plotter unit set to 984 in order for it to import at the correct size. Strange but true!
    Edit: I’ve just tried this in ver 9 coreldraw and it works perfectly without me changing any settings.
    13 March 2006 at 23:33
    I don’t know why this should be – try saving as an .eps file instead
  • Andy Gorman
    13 March 2006 at 23:38
    Are you re-opening in corel or something else?
  • Fran Hollywood
    13 March 2006 at 23:59
    Andy,
    thanks for the info. I will try adjusting the settings, l wasn’t aware of them ….never had to change them.
    I normally open the files in the machine s/w and noticed the difference so l reopened the file in corel and noticed it there too.
    Phil saving as an eps wont help in this situation. Cheers
  • Andy Gorman
    14 March 2006 at 00:15
    Just for information, the plotter units should say 1016 by default. Both for export and import.
