Home Forums Printing Discussions General Printing Topics trouble printing long banner
  • trouble printing long banner
    Posted by Josh Steenbergen on 1 August 2006 at 16:17
    I am trying to Print out a 4ft X 80Ft banner…the files is around 2 to 2.5 Gigs…I was built in Illustrator 12…I had them make a PDF and Eps file of the original Illustrator file(file is 1/5th the original size)…I went to rip file in Postershop 6.5 and it opened preflight up, I told it what material, size I wanted it and everything else that was needed to be done in preflight..then it error-ed out:
    error message was: %%[height to large: reduce by factors of 2]%%
    %%[error checklimit:offending command @ showpage]%%
    I am not sure what that means…Did I have designer prepare file the right way..if not, could anybody give me some pointer on how to fix this problem…
    Thanks,
    Josh Steenbergen
    Shane Drew replied 19 years, 5 months ago 3 Members · 4 Replies
  • Kevin Flowers
    1 August 2006 at 21:27
    Josh
    at a guess i would say Poster shop has a preset roll length & your design is outside of those dimensions. Just my thoughts, i would be curious as to how long it takes a 2.5 gig file to rip.
  • Josh Steenbergen
    2 August 2006 at 00:25
    I already changed the presets for material roll..thought of that when the error poped up the first time…
    thanks for the thought though
    Josh steenbergen
  • Josh Steenbergen
    2 August 2006 at 00:27
    Roland I was wondering if you know anything about this…
    thanks,
    Josh steenbergen
    2 August 2006 at 04:33
    sounds like a memory problem in your printer Josh.
    I had a similar problem with my Roland some time back.
    The roland rep told me to send my file at 25% of actual size, and let the rip do the muliplication by 400% at ripping.
    Never had a problem since, except when I forget and tried to RIP a big file again.
    The error message seems to indicate it wants it at 50% size to the rip?
    I rip 1.5gb files but any bigger and I have to go the reduction route.
    Hope that helps.
