Home › Forums › Sign Making Discussions › General Sign Topics › Tray sign installation instructions
Posted by Cheryl Smith on 18 July 2011 at 09:57Hello
I am going to attempt to install a tray sign for the first time along with my new trainee pair of hands…
Does anyone have any instructions or tips for this type of job…ie the type of wood to use behind or anything that would help me gain confidence in doing this…?
many thanks for any input…
CherylDavid Rowland replied 14 years, 3 months ago 11 Members · 18 Replies -
its fairly easy so dont panic I tend to use ally angle rather than wood and try to set the two pieces a couple of mm smaller then the trays internal dimensions so it slips over easy but close enough not to pull the returns in noticeably when you screw tight
i am with john on the ali angle
normally put the tray on the bench reverse and make some wooden batons to fit in between the angle brackets
much easier when fitting(think i got this idea from peter normington)
you can put top and bottom brackets up remove the batons and tray should slip over nicely
if into brick or concrete we use thunder bolts saves hassle drilling and plugging
Derek
quote Derek Heron:i am with john on the ali angle
Derek
cool…Im not sure I understand about the wooden batons? what are thunderbolts?….ill have a surf to see…
The batons are just wooden spacers between the top bracket and the bottom. Saves you measuring on the wall etc.
Thunderbolts I assume are Dyna bolts. Thats what we call them down here.
Hi Cheryl
have look on ashby’s web site
I’m sure there a technical pdf on wall mounted trays
its under Technical tab
hope that may help
Patrick
Use Tech screws for fixing into place. Self drilling & look ok to.
excellent everyone…thanks for all the tips….feeling a little more confident in doing these now 🙂
hm.. i would make battens fit tray
position batten up
screw thru to other side with drill and spirit level
4" hammer screws into wall
put tray over battens, screw in from top and maybe holding screws on top
cover any screw caps with vinyl -
quote Dave Rowland:hm.. i would make battens fit tray
position batten up
4″ hammer screws into wall
cover any screw caps with vinylyes Dave, thats how I guessed It could have been done in the first place…but I was not sure that if there was a better way…especially that when i was last supplied with a tray sign, there were ali angle bits with it…..
Dave are you having a moment again :lol1:
I would never fit a tray using wooden batons.
quote Dave Rowland:Good old wood, tried and tested.
Yeah but no but, wood needs to be prepped, ally is a better material Dave,
also tried and tested, yes, they used to build airplanes with wood,(spruce Goose) but ally won the day!Peter
If the wall is flat use Aluminium, if its heavily pebble dashed etc or has that really lumpy council house style lumps on it or a very uneven surface I use steel angle, as when fixing ali can pull it out of shape. mind you I live in Cornwall where everything is never straightforward.
Wood can fail over time, it’s a nice moisture trap behind a tray.
im sure the print will fail before the wood
dont over do a sign imo
I used to make up full alloy angle backing mounts – not a wooden baton in sight.
Then I started noticing that every other company round here puts up two wooden batons…and slips the tray over them. Looks the same – does the same job…only saves a load of time & effort.
wood…well, it’s going to last 10-20 years if not soaked…print, maybe 5-7 years or do.
yep… indeed… time is money
also u be back to rebrand them before long…. well maybe in our village 😀
