Home Forums Sign Making Discussions Vinyl transfer sheet wont grab onto the vinyl why is this?
  • transfer sheet wont grab onto the vinyl why is this?
    Posted by TheDecalMan on 2 July 2005 at 01:20
    Hello Everybody – I am having a little difficulty with some chrome Vinyl i have. My Problem is After weeding and applying the Transfer sheet to the Chrome Lettering the Transfer sheet Still does not grab on to the vinyl and lift it from the Backing Sheet.
    Things i have tried :
    Ritek Paper Transfer Paper
    Ritek Clear Transfer Film
    Cleaning Chrome Vinyl with "KLEB-EX" Prior to applying Transfer Films & Papers.
    Still the chrome vinyl prefers to stay on the backing Sheet instead of the Transfer Film.
    TheDecalMan replied 20 years, 5 months ago 6 Members · 11 Replies
  • 11 Replies
  • Jayne Marsh
    2 July 2005 at 10:05
    Is the application paaper you are using low, medium or high tack? I haven’t had a problem with chrome vinyl and use a medium tack application paper.
  • Steve Dawson
    2 July 2005 at 10:25
    Masking Tape !!
    Work a treat for me , removal takes a little longer though
    but then I’m a novice…
    I did a 6ft banner the other day with masking tape alone , worked out fine , just takes a bit of work getting it off without pulling….
    i haven’t got a bench set up at the moment , so wide applications of application tape is a bit tricky for me….a few strips of wide masking tape is allot easier…..
    Sorry , i bet its a no no in the sign game , but it does work for me….
    SD
  • TheDecalMan
    2 July 2005 at 11:28
    Thanks GEM & Gypsy 😀
    I have been using a Medium Tack with both Paper & Film Transfer Sheets – So Perhaps i Should Try a High Tack GEM just for the Chrome Vinyls (I will order some in and give it a go) I never used to have problems with the chrome Vinyl until just Recently & I still buy the same make i always have !
    As for Gypsy’s Suggestion of using Masking tape – It’s a real good idea but because i sell the Decals to the customer to fit them selves i feel it would look unprofessional, But again its a good idea if it works for you Gypsy – Thanks for the tip ! – It may come in useful if i have to fit any myself.
    I also wondered if temperature has a roll to play in this Problem as the room i make the graphics in at present has been quite warm due to the present weather + the vinyl cutters & Computers all produce heat, and the room is quite small . Any thoughts ?
    Again thank you both for your kind advice ! 😀
  • Steve Dawson
    2 July 2005 at 11:54
    yep , agree , no good for the customer , sorry , didn’t realize we where talking customer fit…
    Another thing is that masking tape isn’t much good if left for a while , the sticky leaves some residue if left for a while , i only use tape for quick transfers….
    SD
  • Jayne Marsh
    2 July 2005 at 11:56
    Just another thought……….when you apply the aplication tape to your letters I presume that you squeegee it down really well before attempting to lift the letters off the backing paper 😀
  • Iain Gordon
    2 July 2005 at 11:59
    Following a tip i read on the boards:-
    Try removing the backing paper from the tape rather than tape from backing paper.
    I do this all the time and find it a lot easier
    Iain
  • TheDecalMan
    2 July 2005 at 18:09
    I Do Squidgy them well as i have a home built Press that i stick all the decals through , Consists of two large rubber rollers with a handle on the end (A bit like the old fashioned mangles) – This i built from parts out of 2 Citizen Printers, I also sometimes use A block of felt that came with one of the vinyl cutters when graphics are to big for the press.
    I will have a go at removing the backing from the Transfer like FredTHElad suggested sounds like it could work – Why did i not think of that 😳 – I suppose you get set in your ways & Blind yourself to the simple things !
    Many thanks again Everybody – Think i will have to apply for Gold Membership as this forum has been so help full
    2 July 2005 at 19:26
    also make sure your cutting blade is not set too deep… 😀 this is also another cause of you vinyl not coming away from the backing paper
  • Jayne Marsh
    3 July 2005 at 19:04
    Good tip Ian, I do that all the time, works really well especially on small stuff
  • Alan
    4 July 2005 at 12:38
    Try placing the graphics face down and squeegee the backing paper, this usually helps.
    If that fails try pulling the backing paper over the sharp edge of the bench, as if you were removing creases from a sheet of paper.
    Alan
  • TheDecalMan
    8 July 2005 at 23:41
    Thank you Alan – Your Idea Works 😀 – I tried it face down and Hey Presto they work a dream, I have done a few MG Decals and all worked fine. So i will re-wright my instruction sheet for chrome decals.
    Many thanks to all who have given me ideas on how to cure the problem!
    THX 😀
