Traffic information signs….
Hello people….well my first job…real job… has been and gone (20 H&S boards….6 lines of text and 6 H&S logos per board…. for a building site. Boy did I learn about weeding from that job… (<( )
Anyway I am in need of some advice from the good people of this site. I have an enquiry regarding road signage production. The signs are 250mm diameter (customer supplied substrates….dibond or similar I believe) requiring the standard red outer ring/white background and black alpha/numerics. Also required are standard blue backgrounds with white info graphic…(one way/keep left etc etc).
Having searched UKSB I understand that the reflective vinyl for these signs is problematic to cut….blades blunting quickly etc.
So my question is:
Is it the case that the ‘industry/DoT standard’ vinyl for these signs is difficult to cut? I will be cutting using a Graphtec 5000 if that helps in your replies.If it transpires that I can cut these graphics do they require edge sealing?
Lastly….any advice regarding production tips/pitfalls with this type of signage would be very much appreciated….
Many thanks…..
