Home Forums Sign Making Discussions Off Topic Chat To stand or not to stand…..
  • To stand or not to stand…..
    Posted by Martin C on 7 August 2003 at 22:31
    Simple one this..I think?
    I have a basic Roland plotter and have always run it off the top of a desk never got round to buying a stand for it. 😕
    So…are they better, a waste of money or an essential piece of kit?
    I do a lot of short run Flock Transfer stuff not yards and yards at a time………so don’t really need a basket….or do I?
    Martin C replied 22 years, 5 months ago 5 Members · 5 Replies
  • Neil Kelly
    7 August 2003 at 22:39
    Id say its probably ok but if you start to cut media over a 1m then the drop of the vinyl off a stand and vertical to the floor will help with any alignment problems its agravity thing 😆
    I made my first stand out of mdf and had the graphtec media rollers on a shelf below worked a treat for years the current plotter has rollers built in underneath Muto 1300 s the only problem was the media hitting the floor and picking up fluf and dust so we made a clear acrylic cradle to keep it clean its amazing how much longer our blades last now.
    Neil….
  • Kevin.Beck
    8 August 2003 at 06:44
    My PC600 (which is the same cutter, with a print add on ) came with a stand. I found it ran alot straighter than the Roland that came with a little “tray” to hold the vinyl.
    The stand was higher than a desk, so it helped with back ache, as you weren`t bending over it.
    But if you are only using small bits of material, don`t bother.
  • Mike Brown
    8 August 2003 at 07:16
    Martin,
    I run our plotter from a stand – for me, it keeps it out of harms way. I don’t end up with other bench-clutter around it and whether or not I’m doing long cuts – the basket always keeps things clean.
    more soon
    mikethesign
  • Deleted User
    Deleted User
    8 August 2003 at 09:08
    There wasn’t a stand made for my Roland PNC950, so I bought an old mobile computer table with pull out keyboard drawer, removed the drawer, and ct the table and base in half along it’s width to make a perfect fit stand.
    Everyone who’s seen it thought it was a factory supply.
    It’s on castors and has a lower (printer) shelf onto which I put the roller with the which the vinyl roll sits on.
  • Martin C
    8 August 2003 at 16:49
    I have one of those Computer Tables Peter, but I’ve got my heat press on it!
    I’ll see how my planned move around leaves me for space, thanks all for the advice.
