Home Forums Vinyl Cutter Discussions General Cutter topics This intrigues me, why is it so??
  • This intrigues me, why is it so??
    Posted by Richard O on 20 November 2011 at 22:53
    Just trying to work out why when cutting temp tatts stencils, the cutter starts cutting one stencil then will wander off and start doing another one and so on, then come back and finish off the first one, then wander off and finish off the others that need doing.
    Why does it not finish the first job before it goes on to the next.
    Some of the stencils are quite intricate and on occasion I have noticed that after the cutter comes back to finish a stencil the cuts do not join up exactly.
    Roland GX24 cutter.
    I usually feed a 1m x 610mm piece, which holds 8 A4 size pages, that have from 8-10 stencils in each and have weeding boxes around them and a weeding box around each to seperate the A4 pages.
    Thanks in advance
    Rich
    Richard O replied 14 years ago 4 Members · 11 Replies
  • 11 Replies
  • Karl Williams
    20 November 2011 at 23:00
    If you are making repeated copies in your signmaking software the software recognizes shapes in the order they were made. so on copy 1 will make a circle then go on to the next copy and make another circle. This will or may happen on every shape on every copy. If you tell your cutting software to produce 100 copies lets say then this will recognize the image as 1 separate job and will produce this first then move to the second one. Had the same problem and this was the only answer I could come up with at the time.
  • Richard O
    20 November 2011 at 23:17
    quote Karl Williams:
    Hi Carl,
    These aren’t copies, each of the A4 pages contain different designs/figures.
    Plus I design them in Vinyl Master Pro then save them as eps and export them to Roland CutStudio for cutting (I have never worked out how to cut from Vinyl Master Pro).
    Or am I missing something in your post??
    Rich
  • Karl Williams
    20 November 2011 at 23:24
    Are you sending all the different jobs to cut at the same time? Might be worth a try exporting as an AI file if you can and see if that rectifies the problem. I’ve not used your software mate so I’m advising blind on this one.
  • Kevin Flowers
    20 November 2011 at 23:38
    Its to do with path direction & the order the design is drawn in, the first line would normally be at the back, 2nd line in front of that etc. Each file saves this info so when you group your files it will cut all the 1st drawn lines which means it will jump from design to design. Summa plotters have a option to ignore this & and optimize cutting, don’t known about the Roland. You could try selecting the entire design & send to back & see if that helps. You may need to have the design ungrouped.
  • Karl Williams
    20 November 2011 at 23:42
    quote Kevin Flowers:
    That’s what I was trying to say but I think you said it better Kevin. 😉
  • Richard O
    20 November 2011 at 23:45
    What I do is design 8-10 stencils, these then fit one A4 size page in VMP then each A4 size page is saved as an eps.
    I have 50 separate A4 pages saved as eps.
    Then I open CutStudio import 8 separate eps as these fit on the 1m x 610mm piece in the cutter, line them up and cut.
    I will try saving them as an AI and see what happens, but I guess for me the bottom line is now that I know it shouldn’t wander off as it does I can work on solving the problem.
    Rich
  • Richard O
    20 November 2011 at 23:59
    Thanks for that Kevin, I will experiment with this idea and see if it helps.
    Rich
  • Richard O
    21 November 2011 at 02:50
    Rich
    Not sure how I managed the double post sorry Rob
  • Richard O
    21 November 2011 at 06:19
    Following on from yours and Karls thoughts led me to the following:
    Seems what was happening was when I imported the eps into Cutfile they became ungrouped so I regrouped them and bingo no cutter wandering off doing as it wanted, it finished each A4 sheet before moving to the next one.
    Many thanks to you and Karl
    Rich
  • Mike Grant
    21 November 2011 at 13:51
    You may also have a "sequence plot" or similar command somewhere. This then cuts the piece nearest to the start point. It can jump about a bit on the height of the vinyl but not on the length. I use this with vinyl over 1.5 meters to stop tracking errors.
  • Richard O
    21 November 2011 at 20:59
    quote Mike Grant:
    You may also have a “sequence plot” or similar command somewhere. This then cuts the piece nearest to the start point. It can jump about a bit on the height of the vinyl but not on the length. I use this with vinyl over 1.5 meters to stop tracking errors.
    Closest I can find is an area command, that can be set up to x amount of meters (can’t remember how many off hand, that helps tracking errors.
    It seems all is good now but many thanks for the help.
    Rich
