Activity Feed › Forums › Sign Making Discussions › Off Topic Chat › Thin Brushed aluminum plates supplier>
Posted by Steve Dawson on July 18, 2005 at 8:06 amHi all….
Does anybody know a place on the net that supplies thin aluminum plates….?
The type used for No Smoking signs / door plaques etc…..(possibly engravers material)
SD
Steve Dawson replied 18 years, 9 months ago 5 Members · 5 Replies -
Hello,
Don’t know about anybody selling them on the net but either Suregrave (0191 417 4505 http://www.suregrave.com) or Engravamet (01902 401666) should be able to help.David
Hi there,
theres a company called one to one engravers Ltd, based in Northampton.Tel: 01604 644604 enquiries@one2one-engravers.co.uk
They may have what you need. They make all sorts and their prices are good.
Cheers,
Cheryl 😀
How thin is thin – Suregrave and Engravemet as mentioned will help.
If you want something thin like trophy plate which is about .5mm thick then try one of the trophy suppliers who may be cheaper than the above. The last job we had was for thin plate to be engraved and we bought it from A T Cannon http://www.cannon.co.uk/
Mike
Why not use Butler Dibond. This has a brushed aluminium finish and is easy to cut 😀
Europoint Display also supply a brushed Aluminium material very similar to Butler Dibond.
thanks guys/galls for your help on this one…
quote rightsigns:Butler Dibond.Sounds interesting , I’ll have a look around for this , as in hindsight cutting could be a problem…
Cheers SD
