Home Forums Sign Making Discussions General Sign Topics The Solution for fitting flat cut lettering on a roughcast wall
  • The Solution for fitting flat cut lettering on a roughcast wall
    Posted by Phill Fenton on 10 October 2017 at 14:19
    How often have you tried to fit flat cut lettering onto a roughcast or brick wall only to find the drill bit slips slightly and the holes for the screws end up slightly out of alignment? Consequently, the cups don’t quite line up with the pegs putting strain on the letters often causing the pegs to snap off.
    Well I think I have the answer.
    It’s a cup or with an extended section for the screw to move within allowing the cup to be adjusted in all directions to line up with the peg.
    The example in the photo below (on the right) is 3d printed and is the same size as a signgeer small simplefix cup (shown on the left)
    Phill Fenton replied 8 years, 2 months ago 7 Members · 10 Replies
  • 10 Replies
  • Myles Brewer
    10 October 2017 at 15:17
    Only one word needed Phil… Genius!! :praiseyou:
    Just sit back & wait for the millions to roll in now :thumbsup:
    10 October 2017 at 15:24
    Great idea Phil, and we’ve often wondered why they haven’t created cups with off centre holes to allow for a little more movement. :thumbsup:
  • Phil Davies
    10 October 2017 at 16:56
    You can get bolts that will suit holes like that already, this handy chart has kept me right in all my engineering life.
  • Iain George
    10 October 2017 at 17:23
    Where can I buy these!!!!! I also want a ratchet spanner to do up the brass locators behind letters.
  • Phil Davies
    10 October 2017 at 17:51
    quote Iain George:
    Thats an easy one, as long as you treat a ratchet spanner as a consumable 😆
  • Andrew O Brien
    10 October 2017 at 19:32
    quote Iain George:
    https://m.ebay.co.uk/itm/WERA-JOKER-Met … mwBanner=1
  • Peter Cox
    12 October 2017 at 08:37
    I have a joker ratchet spanner, it won’t work with the brass locators as it’s only the ring end thats ratchet not the open end.
    12 October 2017 at 18:08
    These’ll do it :-
    http://www.toolexpert.uk/open-end-ratch … rs-2-c.asp
  • Andrew O Brien
    12 October 2017 at 20:54
    quote Phill Fenton:
    These’ll do it :-
    I taught that’s what the wera joker was on the open end
    13 October 2017 at 06:35
    No, the joker only has a ratchet on the ring end
