• temps & Times
    Posted by Michael Potter on 18 March 2009 at 00:22
    Hi I was just reading the thread about Graham’s mugs cracking and finished up by getting really confused re times for mugs.
    we were told 200 degrees centigrade for 7 seconds, which is a lot different to Stevie’s 210 seconds. Can anybody shed light on why so much difference.
    Many thanks
    Mike
    Paul S Martin replied 16 years, 9 months ago 8 Members · 8 Replies
  • 8 Replies
    18 March 2009 at 00:25
    wow that is short proof of is do they come out ok.
  • Michael Potter
    18 March 2009 at 02:21
    Hi Chris
    Actually we are doing them at 180 degrees for 7 sec. and yes they do come out ok. since we have never done them any other way I am not sure what difference we should expect.
    cheers Mike
    18 March 2009 at 03:40
    Not sure if it helps, but when we were looking at buying a mug press, we were told 120 secs. 7 secs seems really short on the basis of that.
    Perhaps it may be worth doing one longer and seeing what the results are?
  • Graeme Harrold
    18 March 2009 at 07:56
    For 7 seconds you will be "flash" heating the ink and giving it very little time to transfer. You might find some of the colouring, especially the darker colours look slightly faded. Do 2 mugs with the different times and compare. I have also been told the longer time is required to "fix" the polymer to hold the dye fast…………..
  • John Thomson
    18 March 2009 at 08:24
    For mugs I use 204 degrees for 180 seconds. I only preheat if the mugs have come out of the garage in winter so are really cold otherwise they just go in at room temp.
    With regards to Greame’s other thread re failures…….I use Chinese mugs and have never had a failure.
    john
  • Stuart Davies
    18 March 2009 at 08:51
    we use xpres mugs and xpres mug press
    4 minutes @ 200
    which we cut down from 4 1/2 minutes
    cant believe you can get away with 7 secs
    must be using a microwave
    stu
  • Andrew Williams
    18 March 2009 at 09:29
    Sounds more like a transfer rather than sublimation. Even if a mug was left in a press for 60 secs then you would still have a faded image. We do lots of mugs so have squeezed the time down as much as possible and are okay on 2mins at 195c. I wouldn’t go much less and might add and extra 10/15 secs if a lot of darker coverage is needed.
  • Paul S Martin
    18 March 2009 at 10:41
    Michael
    What make and model of machine are you running M8
    Paul 🙂
