Home › Forums › Sign Making Discussions › Vehicle Wrapping › Temperature advice on oracal black with air release
Posted by Jan Storgaard on 26 August 2010 at 16:31Post heating stretched areas. Temperature advice, to reset memory, on oracal black with air release. Please advice in C° (Celsius)
Thx.Jan
Shane Drew replied 15 years, 3 months ago 4 Members · 13 Replies -
Jan
Which series of oracle is air release? I recently used the 970, but although it has an option of ar, it is not yet stocked in the UK apparentlyPeter
Hi Peter, im not in the shop now and i cant remember, but i think its the 970 series. Ill check tomorrow. Thx.
Jan -
if it is 970, I dont think there is reccomended temp, it is a car wrap and is not designed for recesses, but like most vinyls the heat needs to be a minimum, rather than an excact figure, go for 90c and you should be ok, no guarantees though
Thx, Peter. Thats what i did. 90 C° but it dosent smell good, tho’ ;o)
Jan
From Oracal Australia site: Hope it helps
Oracal 970ra – Any deep-drawn areas, borders and edges should be carefully reheated with a hot-air gun after coating in order to quickly activate the adhesive substance. It is recommended to briefly reheat the film in deep corrugations to a temperature of ca 120°C. In this way the vinyl becomes a stable structure.
This temperature will not damage the adhesive substance and the car’s paintwork.
Specialized shops offer infrared thermometers which allow exact measuring of the underground temperature. Move hot-air gun constantly to avoid damage to the film.
Finally the film should be pressed into the corrugations again.
When the re-assembling is finished, reheat all borders, edges and corrugations again with a hot-air gun to 150°C.
Remaining tiny air bubbles under the film will diffuse through the film within a few days depending on the ambient temperature.
Only larger bubbles should be slightly punctured by a pin or pointed scalpel and the air should be squeezed out using a squeegee.
Nice post Shane, 120 C° is HOT!, im using a laser and 90° is achievable with a heatgun, but 120 sounds way to much…?
Does anybody else have a comment on this?
Jan, 120 deg is fine. I’ve use it at that temp many times.
Just let it cool before you touch it as it goes rather soft. I use a 3M wheel to push it down though, so there is no chance of it being creased.
The final 150 deg is a bit scary, if you have any small bubbles they will burn, so make sure it OK before you do the final heat run.
rite, tried heating 180 °C today. Worked ok.
BUT what if the surface (bumber ) is painted plastic ?Jan
I doubt it would damage it Jan, Don’t let the heat concentrate on one area too long, but I’d be surprised if it did damage anyway. The heat process to make a plastic bumper is much higher than the temps we use with our heat guns.
Hi All,
Shanes post is spot on although i always shy away from recommending rapid air for deep recesses , ill have a look at the Austrailian web site though , its for this reason we only keep the normal repositionable adhesive version but can get the rapid air from Germany quickly enough if needed.
True Cameron, I’d advise against ra for deep areas too and its a point worth repeating, but I’ve used it with ‘normal’ areas and recesses reasonably well.
