Tech8 has accepted Colorific inks onto its approved product
Tech8 gives full endorsement to Colorific inks.
_____________________________________________After extensive field testing across a range of Mimaki and Uniform wide-format solvent-based ink-jet printers, Tech8 has accepted Colorific inks onto its approved product programme. This brings user benefits that remove warranty issues and the opportunity for extended cover for these machine and ink combinations.
Colorific is now the second leading supplier to be granted approval by Tech8, a status only granted when the product matches warranty specifications. Already in place is support for wide-format printers using Sun Chemical’s Streamline ink series.
Available from specialist distributor, IGS UK, the Colorific products which now meet the criteria required by independent warranty specialist, Tech8, include Bio-U, Elite, Fresh and ProJ3 inks. The first three of these products are being used increasingly in Uniform Grenadier and Cadet printers whilst the ProJ3 version is growing in popularity amongst owners of Mimaki JV3 machines.
Tech8’s warranty schemes encompass most of the wide-format printers currently in use today, with manufacturers including Roland, HP, Mimaki and Mutoh’s own and private label products. Where investors in printing equipment have wanted to reduce ink costs by changing to a reliable third-party solution, existing manufacturers’ warranties are usually invalidated when an after-market alternative is used.
The approval by Tech8 of Colorific inks means that full warranty cover can be maintained, including mechanical, electrical and electronic components. Standard on-site response time is eight hours, and additional services include full installation and training on common hardware and software plus ICC colour profiling for most common RIPs.
Full details on the Tech8 service and warranty registration information is available by visiting:-
http://www.tech8.eu.
More information about IGS UK is available from;-
http://www.igsuk.net.
