Home Forums Printing Discussions General Printing Topics T shirt printing money saver
  • T shirt printing money saver
    Posted by Steve Underhill on 13 October 2008 at 18:28
    For anyone using silicon sheets or the teflon sheet that lasts a lot longer but not forever, did you know you can use the backing paper from normal sign vinyl, it even gives a nice glossy finish to the vinyl after a second press once the carrier is removed. and single piece also lasts ages.
    at £30 for 500 sheets of silicon paper or a tenner for the teflon sheet it does a pretty good job seeing as its going to be discarded anyway.
    Also, for anyone that uses the Ultra cut/Pu/ etc T shirt vinyl, (IE the really sticky backed stuff) and stores pre cut designs ready for pressing,
    the backing paper from vinyl does a good job of keeping the different designs apart and from sticking together, its non stick and nice and stiff so wont bend like silicon paper or grease proof
    I just place my designs on a sheet of that, then put the next sheet over the top, no more stuck together designs and ruined vinyl.
    Jason Bagladi replied 17 years, 2 months ago 8 Members · 9 Replies
  • 9 Replies
  • Adam McGuire
    13 October 2008 at 20:39
    I must admit I have tried the backing paper with good results!
    Great tip!
    Adam
    13 October 2008 at 21:00
    and there was me just getting used to unsticking piles of graphics and you come along with some common sense.
    now i am going to get bored whilst doing Ts
    thank you
  • Alison Falzon
    13 October 2008 at 21:12
    Great tip! It never even crossed my mind to try that!
    Ali
  • Kevin Flowers
    13 October 2008 at 21:44
    I use backing paper & dispose after each press when applying tectile vinyl to multi coloured dye sub football shirts other wise you can get contamination on to the teflon sheet from the ink seeping out of the shirt
  • Karl Williams
    13 October 2008 at 23:32
    Kevin!!!!! A pic at last! Well done mate! Sorry…..I’ll crawl back under me rock now. 😉
  • Steve Underhill
    14 October 2008 at 00:37
    Finally I was of some use to this forum!!!!
    LOL
  • Dave Bruce
    14 October 2008 at 08:41
    Yep, been using it for years, and find the same as Kevin, the colour from sport shirts comes off on to the paper!
    Great tip
  • Steve Underhill
    14 October 2008 at 11:57
    Should have mentioned that on the dye subbed sports shirts it can, yes
    but for normal T shirt printing etc its fine.
    Always change the paper each and every time bottom and top when pressing sublimated stuff
  • Jason Bagladi
    14 October 2008 at 21:20
    Yup, been using this trick for a few years.
