Home Forums Printing Discussions Sublimation Printing t-shirt pressing problem. please help?
  • t-shirt pressing problem. please help?
    Posted by Billy Lawton on 27 February 2012 at 15:02
    I stupidly pressed without a protective sheet (to get creases out) a t shirt I picked up from the Promo show yesterday, and the image on the front has partly transferred to the underside of the top heat plate.
    When it’s cool does anyone have a suggestion of how to clean it back off? Solvent etc?
    Thank you – what a berk!!!
    Billy
    :police: Mod-Edit
    * Please use "Descriptive Topic Titles" when posting.
    * This posts Title has now been edited.
    Some things HERE you may wish to think about.
    Please take a moment to look over our Board Rules.
    Steve Underhill replied 13 years, 10 months ago 4 Members · 6 Replies
  • John Wilson
    27 February 2012 at 15:05
    done this years ago myself, just use a bit of teflon on all your jobs from now on and you’ll be fine 😮
    Failing that, fix the teflon on so it doesn’t come off
    PS how was the show? Not going this year
  • Billy Lawton
    27 February 2012 at 15:34
    Hi John,
    It was OK – too many companies selling the same garments, but some nice new techniques about.
    Magic Touch 123 hot flex is good – really easy to weed and 3 second press – I’m getting some!
    What do you reckon I could clean the press with – or do you think it’ll be OK just using the teflon sheet?
    :police: Mod-Edit
  • John Wilson
    27 February 2012 at 15:54
    I tried to clean mine but not with much luck, i’d say put the press as hot as you can then give it a slight scrap with something to remove what’s there
    but use a teflon sheet and you’ll be fine
  • John Gregson
    27 February 2012 at 16:05
    If it was a screen print then white spirits will take it off – if its sublimation I think you may be stuck so use John’s idea of the teflon sheet taped to the press.
    I did some hi viz without using a sheet and stained the press yellow. 😕
  • Billy Lawton
    27 February 2012 at 18:28
    thanks guys – as luck would have it, as it was cooling I thought I would try a simple damp J-cloth – and it worked – back to shiny new! – I think I got away with that one by the skin of my teeth!
    Billy
  • Steve Underhill
    28 February 2012 at 22:48
    If it is ever sublimation ink, get a bit of polyester and keep pressing it til it takes the ink off the platen, cotton works too but is not so fast.
    I have had T shirt vinyl and platic clothing tags etc stuck on there too before and a plastic scraper gets it off cold, otherwise a lot of rubbing with a microfibre cloth is also good but nothing abrasive obviously.
