Home Forums Printing Discussions Sublimation Printing Swing away heat press
  • Swing away heat press
    Posted by Nigel Hindley on 15 April 2010 at 12:26
    We are looking to buy a new press over the next few days, does anyone have any present recommendations and know of any companies doing offers over this week?
    We have been looking at one from magic touch but at around £800 is this too pricey?
    Stephen Murray1 replied 15 years, 7 months ago 13 Members · 21 Replies
  • 21 Replies
    15 April 2010 at 13:37
    I have a clam style press (HF4500 Sports Press) with Teflon coated heated platten from Europa Leisue/Jarin Industries, I think Graphityp do them too but if I were starting again, had the extra room and could find a coated head on a swing away I would be tempted to get one of those I think. £800 is not expensive for a good quality press.
    Alan D
  • Liam Pattison
    15 April 2010 at 13:47
    Hi Nigel,
    Grafityp had a really nice big swingaway press at the show called the siser ts-one going for £999 i believe, really solid looking unit.
    If i had not just brought a clam press from target i would have gone for it.
    Also the swing away took up a little too much space for me when it opened up.
    They did say, give us a ring thursday afternoon and we might sell you this display model at a discount so you never know.
    Check out the target transfers website they have some nice machines there and they negotiate discounts.
    Liam
  • Nigel Hindley
    15 April 2010 at 13:58
    cheers guys, to be honest I hadnt thought of the space aspect? how much more space do you need over a clam press?
    Nigel
  • Neil Speirs
    15 April 2010 at 14:08
    a clam press uses the same footprint but with a swing away press you swing the top head way over to the right leaving the base accessible.
    http://www.youtube.com/watch?v=UBK6-CnZz-w
    I’d go for a swing Adkins
  • Liam Pattison
    15 April 2010 at 14:10
    There are some really good videos on youtube which explain the difference between clam and swingaway i’ll do a quick search for them for you.
    But particular models may vary and might not swing as much as others im not sure.
    one problem they usually tel you with a clam press you get most pressure at the back of the press and it’s not an even distribution of pressure like with a swing press.
    But the clam press i got has over the top centralised pressure, so look out for that as well, maybe i’m just being fussy now though!
    Here you go-
    http://www.youtube.com/watch?v=IajggMbaaT4
    and here’s the press i got-
    http://www.youtube.com/watch?v=zX7594o3CNo
    can’t tell you if it’s any good though as only just got it out of the box
    Liam
  • Steve McAdie
    15 April 2010 at 14:26
    Worth checking the guarantee as a lot offer 12 months which excludes platen.
    Geo Knight have lifetime guarantee on platen & 3yrs on control equip.
  • Ian Pople
    15 April 2010 at 16:49
    I have the siser ts-one and can highly recommend it.
    Ian
  • Jason Bagladi
    15 April 2010 at 18:07
    Adkins swing press all the way!! Worth the investment (although I got mine for free!!)
  • Nigel Hindley
    15 April 2010 at 18:29
    Cheers guys, lots of good info thank you all for your time – lots to think about!
    Nigel
  • Paul Humble
    15 April 2010 at 20:18
    Adkins Swing Aways that Xpres do are second to none.
  • Jason Davies
    15 April 2010 at 20:26
    Signmaster have a good made in the UK press, solid very impressed, Around the 7-800 mark.
    Jason
  • Tracey Little
    16 April 2010 at 20:32
    If you want to use the WOW transfers from The Magic Touch then they advice that you have a swing away press…..just a thought??
    16 April 2010 at 21:40
    quote Steve McAdie:
    My old used magic touch swing away press is so old it’s painted with hammerite, it’s an atkins press which is almost identicle to the current presses, Tmt estimate it at over ten yr old, bit slow to heat up but still works perfick! Wouldn’t worry too much about a long guarAntee on them!
    Nigel, the swing away I have, 50 cm platen, needs about 2 x 4ft space .
  • Nigel Hindley
    16 April 2010 at 22:43
    Cheers guys, cant thank you all enough for all the info.
    Thanks Hugh I wondered what the brand of the magic touch presses were. Cheers Tracey that’s what we intend to do so it will need need to be a swing style.
    Ill go over this info tomorrow and make a decision by monday!
    Nigel
  • Stephen Murray1
    17 April 2010 at 15:21
    Hi.
    Was just wanting to ask someones opinion of this heat press.
    http://www.ace-apparelcraftequipment.co … P3838T.htm
    Is the price to good to be true? I can’t actually find another site that sells this model to compare.
    The press is just going to be as a little weekend project, so it’s going to recieve relativity light use.
    What do you think. Is it a good deal. ?
  • Jason Davies
    17 April 2010 at 15:34
    Generally yes, you don’t get something for nothing, you’ll probably find that the heat is uneven across the press or the temp gauge is out. I imported a swing away press from China about 18 months ago, it’s not bad but I think I only paid about £150 for it at the time with the exchange rate and everything else that I bought. At the time it was only to produce freebies for customers. For that price I could live with it. As it stands it is now a backup and I have since spent £700+ on a proper one as we have picked up quite a bit of business from our initial idea.
    Looking at the price it is low but I’d hang on and buy a decent one at that size and style for £500. If you want it to be reliable and consistent, once you have it you can work it hard then.
    Hope that helps (from experience)
  • Nigel Hindley
    18 April 2010 at 22:01
    Hi Stephen,
    Just as Jason says, and this is the reason why we are getting a new one. The link you have there is to what looks like the exact model we have and paid around the same though we got it on Ebay. Its really a poor machine with uneven heat distribution.
    Nigel
  • Mark Jahn
    19 April 2010 at 07:26
    I thought that link looked familiar. Google "Joys Sewing Machines".
  • Neil Speirs
    19 April 2010 at 07:45
    quote Nigel Hindley:
    Nigel
    Xpres, Magic Touch & Nova Chromes presses are all re-badge Adkins
  • Nigel Hindley
    19 April 2010 at 19:15
    quote Neil Speirs:
    Nigel
    Cheers Neil think we going with a Magic Touch machine but totally sure just waiting for them and another to get back regarding a wee starter pack of materials!
  • Stephen Murray1
    23 April 2010 at 11:00
    Thanks for the advice guys. I think i’ll steer clear of that one. Looks like i’m just going to have to save a few more pennys and go for one in the £500 – £600 price range. Cheers.
