Home Forums Vinyl Cutter Discussions Summa Cutters Summa D500 cutter, doesn’t cut the whole letter. Help please
  • Summa D500 cutter, doesn’t cut the whole letter. Help please
    Posted by Paul Mills on 24 November 2015 at 16:38
    i wonder if anyone can help ?? my D500 when it cuts it sometimes doesn’t seem to cut the whole letter cleanly making it a pain when weeding out.Any solutions welcome before i buy another machine
    Paul
    Paul Mills replied 10 years ago 3 Members · 4 Replies
  • Pane Talev
    24 November 2015 at 16:45
    I’ve used D60 (my first cutter) and now I’m using D120 Summa.
    In similar cases my problem is fixed when I insert new blade.
    Apart from this I rarely hear problems with Summa cutters.
    EDIT: also check knife / cutter offset.
    24 November 2015 at 17:08
    check blade offset.
    I think the original blades are a .38 (best check) offset, if you’re using smart knives I think they .45mm offset.
    also check the overcut, I think mine is set to a small amount *2 in the settings (menu>system setup.overcut).
    clean the grit roller and pinch wheels?
    other problems might be more involved, suck as worn belts etc.
  • Paul Mills
    24 November 2015 at 17:35
    Thanks alot i will give the offset a try,i put a new blade in a few weeks ago but another is worth a try
    Paul 😀
  • Paul Mills
    25 November 2015 at 16:00
    I think the trouble was sticky bearings on the rollers,i took them off and put some silicone lubricant on them and it seems to be cutting fine now 😀
    Thanks for the tips
    Paul
