Home Forums Sign Making Discussions General Sign Topics Stickytex & UTack wall fabric reviews?
  • Stickytex & UTack wall fabric reviews?
    Posted by George Neagu on 20 November 2019 at 16:12
    I have a project for some wall covering.
    I am aware of Phototex but I was wondering if you have some real life experience of these alternatives?
    Stickytex IJ700
    UTACK Waterbased Textile
    Either option will be printed on aqueous printer and there may be some kiss-cutting.
    I have samples of all 3 materials and is very little difference between but the critical aspect is the adhesive which cannot be judged from samples.
    Thank you
    George Neagu replied 6 years, 1 month ago 5 Members · 16 Replies
  • 16 Replies
  • Iain Pearson
    20 November 2019 at 17:23
    Why Textile George ?
  • George Neagu
    20 November 2019 at 17:39
    quote Iain Pearson:
    Few reasons:
    – it’s textured, I can achieve some special effects on it
    – it can be printed on aqueous without further protection (i.e. lamination)
    – removable
    – easy to install
    Did you think "why not vinyl"?
  • Iain Pearson
    20 November 2019 at 19:04
    We do thousands of Sqm of wall coverings every year but we never use textile. We have been called in several times to replace previously installed textiles that other companies have put up. The only one that I would even remotely recommend is the genuine Phototex EX range. Personally speaking, there are far better non textile products out there
  • George Neagu
    20 November 2019 at 19:15
    quote Iain Pearson:
    Alright then, give us some product names so I can look them up. Thanks
  • George Neagu
    20 November 2019 at 19:16
    quote George Neagu:
    quote Iain Pearson:
    Alright then, give us some product names so I can look them up. Also, what printer do you use for these materials? Thanks
  • Colin Crabb
    21 November 2019 at 09:33
    We use a lot of the Metamark wallart range, really like it.
  • George Neagu
    21 November 2019 at 09:44
    quote Colin Crabb:
    They cannot be printed on aqueous printer.
    I’ve installed once one of their textured PVC wall art vinyl and I didn’t like it. On flat surface it was okay but it was problematic around slightly curved surfaces and corners because it was thick and rigid, it was lifting up. It was looking quite cheap on the wall, I thought ordinary MD3 with matt lam would have looked way better.
    A textile is much softer and goes naturally around all shapes and surfaces.
  • Colin Crabb
    21 November 2019 at 09:52
    Ah, yes we use Latex printers.
    Didn’t really have much issue fitting, but admittedly has been on flat walls!
    Have used matt laminated MD3 also, combined with gloss laminated pieces to create a spot-uv effect!
  • Iain Pearson
    21 November 2019 at 15:00
    Got a number I can call you on George ?
    21 November 2019 at 21:36
    I also use the wallart range regularly. mostly on flat walls but it is vinyl and it’s will can be bent with a heatgun to a fair degree!! Latex here too.
  • George Neagu
    21 November 2019 at 21:38
    quote Iain Pearson:
    I do but it’s the purpose of this forum to share the knowledge and the experience, let’s keep it alive. :smiles:
    22 November 2019 at 08:12
    quote George Neagu:
    quote Iain Pearson:
    George,
    I see where you’re coming from but, it’s probably worth your while giving Iain your number.
    He is extremely knowledgeable on the wallpaper side of things and it’s probably a lot easier for him to call between job on the road, that write it all down!I haven’t always acted upon his advice but I always apreciate his input on a particular task.
  • Iain Pearson
    25 November 2019 at 09:39
    Thanks for the kind words Hugh, and yes you are correct, its much easier for me to pass on experience/knowledge
    via a phone call when i am out on the road.
    I do have extensive knowledge in this area as it is probably 50% of my total revenue, but I’m sure by now George has found the answers he was looking for and thus purchased the products he needs.
    Thanks for the vote of confidence though :claps: :thumbsup:
    25 November 2019 at 10:53
    I’d 2nd what Hugh says – It would not be a waste of your time speaking to Iain.
    I often find it easier to ring people, than coming and going with e-mails.
    These forums are great, but I occasionally receive emails, and calls from members looking for quick bit of advice, and it’s easier to communicate directly.
  • Iain Pearson
    26 November 2019 at 05:38
    Aww thanks David , although if you ask my wife I’m sure she thinks it’s a waste of time taking to me half the time, especially when she tells me not to buy anymore trainers lol
  • George Neagu
    26 November 2019 at 09:04
    I was ill these days and therefore inactive.
