Home Forums Sign Making Discussions General Sign Topics Sticking Foamex to Ply?
  • Sticking Foamex to Ply?
    Posted by Tim Painter on 31 May 2006 at 12:10
    I need to stick a 5mm foam panel to a Plywood backing board.
    Was thinking of sealing the ply with say unibond and using VHB tape.
    Any other ideas welcome?
    Many Thanks
    Tim.
    David Rogers replied 19 years, 4 months ago 4 Members · 5 Replies
  • Stephen Morriss
    31 May 2006 at 14:20
    I do this all the time using Evo-Stik. It says on the tin that it is ideal for sticking wood and PVC among other thing and I’ve never had a problem yet in 3 years.
  • Tim Painter
    31 May 2006 at 14:23
    Thanks 🙂
  • David Rogers
    31 May 2006 at 14:33
    Use Evo-stik as well. Sometimes not on display in the likes of B&Q / Wickes due to HIGH solvent content – just ask.
  • Alistair Richards
    21 August 2006 at 09:30
    Sorry to drag up an old post, but do you guys means Evo-Stick Contact Adhesive, i.e. apply thin layer on both surfaces, let dry then stick together.
    Will this work with alupanel to ply also.
    I’ve got an advertising board to do for a small footie pitch, and I’m not sure what substrate to use. Don’t know if it’s gonna be supported with posts yet or some other system, but I was thinking foamex on ply for strength, or for a better wearing sign 3mm alupanel onto ply, or do you think the alupanel will be ok on it’s own.
    Any ideas welcome
    Ali
  • David Rogers
    21 August 2006 at 11:23
    quote Alistair Richards:
    Sorry to drag up an old post, but do you guys means Evo-Stick Contact Adhesive, i.e. apply thin layer on both surfaces, let dry then stick together………….
    Ali
    Yup, that’s the stuff. Will stick just about anything including the alupanel.
    ….easy to get wasted on it in an enclosed space.
    I would recommend though that you stick the parts together wet and let the solvents dry out slowly – or it’s very much a one-shot affair!!
    Same end result – just takes longer.
