Home Forums Sign Making Discussions General Sign Topics SteelTrak Cutters – any good?
  • SteelTrak Cutters – any good?
    Posted by Warren Beard on 3 February 2011 at 17:26
    Received this special offer today and wondered if a worthwhile investment? Anybody got one that can give me pro’s and con’s?
    SteelTrak Board Cutters
    SteelTrak is the industry standard when it comes to board cutters. They cut the majority of rigid products up to 13mm in thickness. Optional glass cutting kit and ‘V-Groove’ option. Available in 165cm & 210cm cutters. From £2,390
    Offer – Buy a board cutter and receive a FREE stand, glass cutting kit and V-Groove tool worth £490
    Warren
    David Rowland replied 14 years, 11 months ago 9 Members · 14 Replies
  • 14 Replies
  • Colin Aburrow
    3 February 2011 at 17:32
    Hi Warren I have been looking at those as well. I have seen them advertised for £1675 from Jagsign suppliers.
    Colin
  • Derek Heron
    3 February 2011 at 17:54
    me too warren looks a good piece of kit and a few members have them .like the idea of the v cut for making small pan trays etc.
    sure phil fenton has one
    looks like the deal you have been offered is for the large one plus vat and then the freebies
    every time i have to cut some alupanel etc i reach for the catalog and my credit card
    http://www.uksignboards.com/viewtopic.p … highlight=
    Derek
    3 February 2011 at 19:27
    I’m a big fan of the Keencut and used it here
    http://www.uksignboards.com/viewtopic.php?t=44352
    Pros are:-
    Dust free Operation.
    Cuts composite without leaving a sharp edge (no need to debur after cutting)
    Simple safe operation
    The V groove attachment is great for making up trays and simple folded panels
    Downside:-
    You need sufficient head height to install the bigger version (wouldn’t fit in a modern house with an eight foot ceiling)
    Has a tendency to curve composite when cutting smallish panels.
    Even the largest version will only cut up to 2.1M so unable to cut a 2.5M board length ways
    Overall I wouldn’t be without mine now. I used a table saw in the past which created loads of dust and was scary.
    4 February 2011 at 01:48
    quote Phill Fenton:
    :lol1: funny enough, i know what you mean by this… those days are well behind me, but many an eventfull time we had when we just got our flip table saw. 😳
  • George Zerbino
    4 February 2011 at 07:45
    Same as Phill for me, pros & cons but wouldn’t be without it.
    Makes cutting anything a breeze, almost no effort required and nice clean cuts every time.
    4 February 2011 at 08:51
    my question is, how well does it cut thick foamx like 5 and 10mm? is it good quality edge at perfect 90deg?
  • George Zerbino
    4 February 2011 at 09:10
    Dave,
    Perfect edge with 90 degree cut, 5mm you can cut in one single pass if you want to, I prefer to cut in two passes.
    10mm needs 3 to 4 passes, but it’s much easier than using a straight edge and a stanley knife.
    Regards,
    George Z.
    4 February 2011 at 09:24
    well we have several Javelins, we struggle with 5mm edge quality.. do use stanley blades?
  • George Zerbino
    4 February 2011 at 11:56
    I also have a Javelin, which I still use occasionally. Never had a problem with the edge quality, especially not on 5mm. Standard stanley blades.
    Are you putting too much pressure on it when cutting? Is the blade holder loose? How many times do you score before it cuts through?
  • Colin Aburrow
    4 February 2011 at 12:06
    Dave I use a Javelin cutter and had the same problem and was told it was the speed you cut at. I now cut a lot slower and find that I get a much cleaner cut no fracturing at all and lovely edge even 10mm Foamex. So less speed when running the blade across the sheet.
    Colin
  • Gary Birch
    4 February 2011 at 12:23
    quote Colin Aburrow:
    Colin
    We have an old Excalibur and find the slow cut gives a far better finished edge too.
  • Martin Gray
    4 February 2011 at 12:32
    Hi Warren
    I am also very interested in this machine! Would to be to cheeky to ask who is offering this deal?
    Martin
  • Harry Cleary
    4 February 2011 at 12:34
    quote Gary Birch:
    Colin
    Same with mine…’if you’re in a hurry, don’t rush’ as me auld granny used say! 🙂
    4 February 2011 at 16:15
    but my point is, isn’t the steeltrax assembly the same as a jav?
