Activity Feed › Forums › Sign Making Discussions › Vinyl › Sourcing one way mirror film for office window, help please?
Posted by Richard Urquhart on August 25, 2015 at 7:31 pmHi all I’m after a film as in mirror film for an interior office window, you can see out but not in, in the past I have used mirror tint film in the highest block but it’s not worked when used inside before, so looking at a way to do this so it works 100% and I have had the same problem using the contra vision inside, any thoughts please people thanks Rich
Daniel Evans replied 7 years, 7 months ago 8 Members · 13 Replies -
Hi Richard,
It all depends on the lighting.
No matter what film you use it will not work when you have less than 1 in 7 variation in lighting either side of the glass. Try installing lighting directly over glass on the side you want to be mirrored, this can work if positioned correctly.
Hope this helps.
Gil
HI Rich, hear this all the time from my clients, I mention Police TV shows like the Bill in the interview rooms. They sit in near darkness one side and brighter the other to achieve the effect.
My ratio is about 70/30 light split.
If you can direct a spotlight onto the film this helps solve the problem
I think Hexis do a film which is reflective similar to what your after but agree with the above comments
Guys thanks for your help spoken to PMX and we have a possible solution, however now the customer thinks it too much to spend!!!!!
quote Richard Urquhart:Guys thanks for your help spoken to PMX and we have a possible solution, however now the customer thinks it too much to spend!!!!!
nothing to add but agree with the comments above mate.
Your customer sounds like most these days… "oh it MUST do this and that, but cant be expensive!"
bit like… "oh i must have those Versaci Jeans, but can only afford the price of Wrangler" 🙄 then Wrangler it is, wise up skint boy! 😛 :lol1: -
YES and its an hour im never going to get back just trying to problem solve !!! still may help for future jobs , thanks Rich
Richard, how did you get on with this?
I’ve got the same requirement.
I’m pretty sure he bought Wranglers instead :awkward:
Bonwykes stock a wide range of this type of film.
Thanks Steff, I gave them a call late this afternoon, getting some samples sent in the morning
