Home Forums Sign Making Discussions General Sign Topics solar/tinted windows question
  • solar/tinted windows question
    Posted by George Elsmore on 26 February 2016 at 08:45
    Morning All, quick question which i think I know the answer to, is it possible to strip/remove the solar window tinting from office windows I am pretty sure once its on its on or is there a secret method to get it off?
    Cheers G
    Stuart Miller replied 9 years, 10 months ago 6 Members · 9 Replies
  • 9 Replies
  • Ian Jenkin
    26 February 2016 at 11:02
    Horrible stuff to work with 😉
    What we’ve done with some degree of success is to App tape the film and spray down with water.
    And leave it.
    Then return the following day and hey presto!
  • George Elsmore
    26 February 2016 at 11:27
    hey presto all the film comes off?
  • Ian Jenkin
    26 February 2016 at 13:41
    In some circumstances yes, it comes away cleanly.
    That said it doesnt always work – but its worth trying for the sake of some app tape.
  • Chris Windebank
    26 February 2016 at 14:46
    do a video search George, some use water and a dustbin liner, has the same effect. Amazes me how water gets through the film and softens the adhesive.
  • David McCarroll
    27 February 2016 at 06:19
    It’s not hard at all, labour intensive but charge well as everyone does.
    Get yourself a 6 inch triumph scraper, if your lucky the film "may" come off in one piece then use the triumph to scrape Majority of the glue off then a good glue remover or 100% isopropyl to get residue.
    The process of sweating the film off does work but it’s long. If you think about the amount of tape and putting it on all the windows plus traveling back and forward that day then it usually works out as a long way for a short cut. The only time we ever sweat film off is on saloon/coupe cars where access is tight to ensure all the glue has gone.
    As a rule of thumb, we charge 50% of the install cost for removal so if the new film is £1000 (or would be if it was getting fitted) then removal would be £500.
  • Gary Barker
    1 March 2016 at 22:36
    you could try ImagePerfect™ Vinyl Remover Pro I know it works with vinyl graphics can’t see why it might not work for tint films
  • George Elsmore
    2 March 2016 at 12:07
    UPDATE : Been and had a look and had a go at pulling some off it came off a doddle with little effort and no residue just got to price up now for removing 600 windows 😮
    cheers for everyones input
  • Gary Barker
    2 March 2016 at 12:43
    quote George Elsmore:
    thats just the first one lol you will get the order then boom they will be a right **** to get off 😉
    good luck.
  • Stuart Miller
    2 March 2016 at 16:30
    take a good look as film which comes off easily often leaves a layer of adhesive which may at first not be seen.
    Still use a scraper and isoproponyl to check if any residue.
    If film is stuck hard then using a sharp knife it can be scored into 6" wide strips which are easier to remove.
    I charge by the hour at £30/hour, as you never know if its goingto be 5 mins or hours.
