Home Forums Software Discussions General Software Topics Software issue means my graphtec will only cut tiny numbers!
  • Software issue means my graphtec will only cut tiny numbers!
    Posted by Liam Pattison on 21 June 2009 at 19:31
    this is probably a really stupid question. i have a graphtec CE5000 120 cutter and i am using it with vinyl master pro. When i output my work to cut the cutter just cuts a series of tiny numbers.
    I’m sure it’s a software issue as the software which came with the cutter works fine.
    I’ve tried the cutter on a mates flexisign now and it also only cuts a series of tiny numbers.
    Is there something i am not setting up correctly in these softwares which causes this to happen?
    I would really appreciate any help as this is driving me slightly crazy.
    Liam
    Liam Pattison replied 16 years, 5 months ago 3 Members · 6 Replies
  • Brian Hays
    21 June 2009 at 19:35
    You are probably using a HPGL diver when it should be GPGL or vice versa.
  • Liam Pattison
    21 June 2009 at 19:51
    thanks Brian i will give that a try, must be something simple like that.
  • Brian Hays
    21 June 2009 at 20:31
    It will almost certainly be a language problem if the numbers are tiny single line ones (ie ones that you cannot weed) You can switch the Cutter between HPGL & GPGL so can change that rather than the software if you prefer.
    22 June 2009 at 07:40
    I reckon Brian is right, Cutting Master comes with the Graphtec and that only works with gpgl. When I use Signlab that driver is hpgl.
    Alan D
  • Liam Pattison
    22 June 2009 at 10:57
    Thanks both for your advice i’m going to try this later when i get chance and will let you know how i get on.
    Liam
  • Liam Pattison
    22 June 2009 at 14:23
    Ok thanks very much to you two for your advice as it helped to solve the problem a great deal. 😀
    Let me just explain exactly how i sorted it in case anyone else has the same problem and finds this thread, i don’t want to just take from here so i will try to contribute-
    First of all i downloaded the full manual for my graphtec cutter from their website. Then i found out how to change the cutters language setting to HPGL. I then had to make sure my software was communicating in the same language.
    Then finally i found out the changes only took effect when i switched everything off (cutter and computer) and restarted them. Now everything is working fine.
    Thanks again!!!
    Liam
