Home Forums Printing Discussions Roland Printers Snapped manifold
  • Snapped manifold
    Posted by Mark A Brown on 5 August 2013 at 12:15
    Omg. Help.
    The manifold on which the dampers go onto has just snapped. The head is fine but the nipple the damper goes on is snapped a little. Can I just replace the manifold as I can buy the part from digi print supplies for 9 euros. Is it an east thing to do as don’t fancy forking out for a whole new head plus fitting.
    I feel sick now.
    From Mark
    Stafford Cox replied 12 years, 4 months ago 4 Members · 4 Replies
    5 August 2013 at 13:25
    yes you are correct and can order the manifold, when u do take it apart u will find a rubber seal, make sure u get this or try and use the one that u have.
    5 August 2013 at 13:29
    Yes the Manifold can be replaced, we had ours done last year after snapping one of ours.
  • Mark A Brown
    5 August 2013 at 18:29
    Thanks guys for your help. I don’t feel as sick any more.
    From Mark.
    Ps. Now I’m trouble with the pc communicating to the printer. Thinks its just one of those days where your being tested to the limits lol
  • Stafford Cox
    6 August 2013 at 17:07
    Absolutely can be done as the guys have pointed out already. You will need to do some calibrating of the head to get it perfect but shouldn’t be too far out. Make sure you don’t over tighten it as that will restrict the ink flow.
    Stafford
