Home Forums Software Discussions Signlab Software Signlab-Graphtec ERROR – Cannot find USB Plotter
  • Signlab-Graphtec ERROR – Cannot find USB Plotter
    Posted by hippocket on 14 February 2014 at 04:15
    Hi All,
    I am hoping someone can help me.
    I have previously used a laptop dock which has extra USB ports where my cables that connect to my Graphtec cutter were plugged into. It no longer works so I am now using a multi plug USB adaptor that is plugged directly into my laptop USB port. When I try to send to cut it is coming up with an error message
    Cannot find USB plotter GRAPHTEC CE5000_USB002+
    I am guessing I need to change settings somewhere to a different USB port?
    Megan
    Ray Wilcox replied 11 years, 10 months ago 1 Member · 1 Reply
  • 1 Reply
  • Ray Wilcox
    14 February 2014 at 14:18
    Go To Cut > Plotting Defaults > Setup > Port.
    In the top right corner is the port, it will currently show GRAPHTEC CE5000_USB002+ , click on the down arrow at the end of the port name to show all of the ports, You should then see one with a very similar name (the USB002 will likely have changed. Select the new one and then OK your way out.
