Home Forums Software Discussions Signlab Software signlab 7 measurement issues
  • signlab 7 measurement issues
    Posted by Simon Stonuary on 5 September 2011 at 09:21
    Hi all after a recent upgrade to my pc i`m having a few problems with signlab.mainly there are no units of measurement displayed on screen anymore, when say creating a box or if you click on a image.the measure tool works but displays no dimensions.also when cutting has finished the done box doesn`t appear so i have to close signlab and re open to continue working.any ideas as i`m struggling
    thanks simon
    Brian Hays replied 14 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Brian Hays
    5 September 2011 at 09:58
    Have you got the rulers turned off?
    Go to ‘view’ & ‘show rulers’ if you have. Or press alt & R.
  • Simon Stonuary
    5 September 2011 at 10:05
    Hi Brian
    the rulers work ok , but if you click and drag a box shape or click on a item , previously the size would be displayed at the top of the screen
  • Brian Hays
    5 September 2011 at 10:55
    You need to open the registry editor.
    Close your signlab first.
    Goto start (bottom left) then run.
    Type "regedit" in the dialog box, then click ok.
    This will open the registry editor.
    Double click the folder "HKEY_CURRENT_USER"
    Then double click the "SOFTWARE" folder.
    Double click the "CADLINK FOLDER"
    You should then see a folder with a date on, double click that.
    You will then see another "CADLINK" folder, double click that.
    You will then see a folder "TOOLBAR INFO"
    You need to right click this folder & delete it. Next time you open Signlab then everything should work as it did.
    Sounds long winded but should only take a couple of minutes.
  • Simon Stonuary
    5 September 2011 at 12:13
    Hi Brian i have got to the double click on cadlink but there isnt a folder with a date on it.
    chariot
    signlab 6
    signlab 7
    are the folders available
    thanks for looking for me
  • Brian Hays
    5 September 2011 at 12:47
    Sorry Simon, Signlab 7 will be the one (as that’s the version you are using) I have loads of versions on this PC & Most of them show dates & not version numbers.
  • Simon Stonuary
    5 September 2011 at 13:19
    Thankyou Brian
    all sorted now
  • Brian Hays
    5 September 2011 at 18:15
    No problem, glad that I could help.
