Home Forums Software Discussions Signlab Software Sign Lab 7 vinyl cutting problem
  • Sign Lab 7 vinyl cutting problem
    Posted by Assad Hussain on 10 October 2011 at 13:59
    Hi People, have a small problem with Sign lab 7, can anyone tell me how do I set up my artwork so when it goes through the plotter it don’t cut from different place but only starts the cut from the beginning of the page and finishes on the end of the page. This way my media don’t come off the rollers. I know there was a short cut to do this but can’t seem to remember it, I have had a look in the manual still no luck. Appreciate any help thanks
    Assad Hussain replied 14 years, 2 months ago 3 Members · 6 Replies
  • Paul Loades
    10 October 2011 at 14:16
    Hi, if I remember correctly go to Cut ( drop down menu ) then select plotting defaults and there is the facility to select start and end points for cutter.
    Select where you want start and finish then apply & save.
    Paul
  • Assad Hussain
    12 October 2011 at 14:53
    Thank You Paul for the respond, ive given this a go and it seems to make
    no changes, the plotter still cuts from different places on the vinyl.
  • Peter Dee
    13 October 2011 at 09:00
    Try this;
    Go to Plot. Select the object start point to be current and select SORT.
    Save defaults and apply.
    Select Setup. Select START origin and END origin points.
    When you go to CUT, select the type of sort you want; vertical/horizontal etc. Select "show sort numbers" to check it’s as you want.
    I don’t know why your media is coming off the rollers. Do you mean at the end of the vinyl or is it moving sideways?
  • Assad Hussain
    14 October 2011 at 09:38
    Hi Peter, Thank you for the info much appreciated, I’m having problems finding (Select Setup. Select START origin and END origin points.) rest seems to be fine, could you please guide me to the right direction please thank you
    Azz
  • Peter Dee
    14 October 2011 at 10:03
    Cut/plotting defaults/setup. Sorry I always just hit the setup icon on the toolbar.
  • Assad Hussain
    14 October 2011 at 10:39
    THANK YOU PAUL :lol1: :lol1:
