Home Forums Sign Making Discussions Neon, LED, Lighting Sign frame help
  • Sign frame help
    Posted by Richard Urquhart on 28 February 2009 at 20:36
    Hi all I normally make my signs in to trays and don’t really use a frame, however customer would like a frame sign so it will match his other branch, the problem is I can get access from sides or top so how would I push the di bond panel into the frame or can I get a front loading sign or would I need to make a hanging rail ?
    The sign is 20 feet x 3 feet
    If I hang it from the top rail and then fit the bottom trim what will hold the lower part of the frame in place other than the 2 corner clips, please help
    Rich
    or can a get a face loading type frame??
    Kevin Flowers replied 16 years, 7 months ago 3 Members · 3 Replies
  • Richard Urquhart
    28 February 2009 at 20:41
    Just think I found the answer on SMP they have a front loading fame section
    thanks Rich
  • Warren Beard
    28 February 2009 at 21:56
    Hi Rich
    Yes you can get a front loading frame system so what you see on SMP is correct.
    Just in case you were doubting yourself 😉 :lol1:
  • Kevin Flowers
    28 February 2009 at 22:37
    Rich
    most frame sections will accept front loading, its just a case of making the panel the correct size. You do need a hanging strip, basically you put the panel in at 45 degrees lift it up & drop into lower trim, push all the way to one side then do the same with the next panel. Did have a instruction sheet for sizing etc on double & multi panel signs. SMP do the Roller Bead which is front loading and is very easy to use but is a ugly looking frame.
