Home Forums Sign Making Discussions Vinyl Short term bubble free printable vinyl
  • Short term bubble free printable vinyl
    Posted by Warren Beard on 9 September 2010 at 17:43
    OK what I actually mean is a "cheap" bubble free vinyl to print on my Roland. I have a client who wants a large quantity of graphics but want to fit themselves as it is not financially viable for me to travel the UK to apply logos to the doors only. I would like to supply a bubble free graphic for their guys to apply, only needs to last 2-3 years at the most.
    Any recommendations or suggestions?
    Warren
    John Hughes replied 15 years, 1 month ago 6 Members · 10 Replies
  • 10 Replies
  • Ian Johnston
    9 September 2010 at 18:11
    use a repositionable vinyl, it’s very easy to put on, and fairly cheap. also a lot thicker so client won’t balls it up
    9 September 2010 at 18:20
    bubble free and cheap are not 2 words that go together, otherwise most vinyls would have the feature!
    When you say doors, do you mean vehicle doors?
    if so I would just use a thicker label vinyl laminated, it is easier to fit by joe public, but the alternative would be to supply instructions on how to fit wet….
  • Warren Beard
    9 September 2010 at 18:23
    Thanks Ian and Peter, I think you might have it right, can you recommend any?
    Warren
  • John Enright
    9 September 2010 at 18:38
    Hi Warren, i’ve been using image perfect IP2503PA from spandex its around £200.00 per roll (50m) it prints well and the bubble free works well even with over-laminate
    ive attached the data sheet for your reference.
  • Warren Beard
    9 September 2010 at 18:45
    quote John Enright:
    what width is this?
  • John Enright
    9 September 2010 at 18:49
    Warren, roll with 1372mm x 50m
    9 September 2010 at 19:06
    that is not cheap, but depends on the size of the decal you are producing, as to the cost per unit, Metamark mdp 200 is about half the cost but you would still need a laminate as well?
  • Nigel Pugh
    9 September 2010 at 19:31
    The people who will be fitting the graphics are they vinyl experienced, just asking because if they are not then how will bubble free vinyl cheap or not be an aid to them.
    There are plenty of mid term vinyls available now which should all go down very easy if you know what you are doing, I would ask if they know what a squeegee is then decide what vinyl to use 😉
  • Warren Beard
    Thanks guys, I think it is easier and cheaper to go with the likes of Metamark MDP as Peter suggests
    Thanks guys
    Warren
  • John Hughes
    9 September 2010 at 21:24
    new product from spandex
    http://www.spandex.com/UK/Spandex/News/ … 534PA.aspx
    john
