Home Forums Sign Making Discussions General Sign Topics Shop Window TV Screen Players – usb/wifi
  • Shop Window TV Screen Players – usb/wifi
    Posted by Shawn Bentley on 20 June 2016 at 08:15
    hi guys,
    hope your all having a great monday morning 😕 , I’ve got a client that wants a screen approx 600mm width by 700mm height (can be varied) have to be a monitor that can face the sunlight as going in the flat a window of a van, i know estate agents use similar ones and needs to be thin with usb/wifi connectivity and either 12v or could be run through an inverter, so images can be changed from a central server etc, any ideas or advice would be gratefully received, cheers shawn
    Shawn Bentley replied 9 years, 4 months ago 4 Members · 6 Replies
  • Kevin Flowers
    20 June 2016 at 09:59
    Shawn
    try Fairfields will give you a starting point costs can be high and maybe frown upon by Police as a distraction etc
    fairfielddisplays.co.uk
  • Shawn Bentley
    20 June 2016 at 10:16
    cheers kev, its for a ice cream van so would only be on serving window when they are serving so should be ok, ill check them out cheers mate,
  • David Rogers
    20 June 2016 at 13:51
    We’ve done a few of these as an alternative to menus in take-aways / supply files for upload.
    Doesn’t need to be anything fancy these days as most single screens can show a slideshow from a USB or run something a lot fancier from a small nettop PC or even a Raspberry Pi II. Multi output animations over 5 or 6 screens with the right software etc etc
    We’ve had excellent results from the cheap ‘home brand’ HD LED from Tesco with the added advantage of a good warranty or Samsung for a slightly neater / smaller bezel.
    Viewing in direct sunlight will ALWAYS be an issue…
  • WOW Graphics
    20 June 2016 at 15:00
    You will need an inverter to run these on 12v.
    Also you will be lucky to find a high brightness monitor thats thin. Looking around 80mm
    Darren
  • Kevin Flowers
    20 June 2016 at 22:54
    WOW Graphic’s
    please read the site rules self promotion is not permitted & suppliers have to register as suppliers, a introduction in the hello section normally goes a long way as well
  • Shawn Bentley
    21 June 2016 at 10:49
    hi guys thanks for all the comments, will look into all of them cheers kev,
