Home Forums Sign Making Discussions Gallery shop signage: parklands
  • shop signage: parklands
    Posted by Phill Fenton on 23 May 2003 at 07:49
    I find that a jigsaw can mark and scuff the vinyl when cutting foamex with the sign already applied. I think it’s better to cut the overall shape in reverse and apply this to the back of the board to cut out the shape. Then apply the vinyl design to the front of the board.
    Not sure how to treat the edges though – maybe paint as you have suggested.
    Neil Kelly replied 22 years, 6 months ago 8 Members · 9 Replies
  • 9 Replies
  • Simon Clayton
    23 May 2003 at 08:23
    We would lay vinyl first then jigsaw (trying to match the vinyl to the shape can be tricky, to stop scatching either completely cover with application tape or put some loop velcro on feet of jigsaw..(works a treat)
    The edges we would use black permanent marker pen.
    By the way great design
    Simon
  • Alan
    23 May 2003 at 08:24
    Hi Gray
    Just a thought but you could try using one of the blades for cutting kitchen work surfaces. The ones that have the teeth face the other direction so the cut is on the down stroke of the jigsaw, this may help alleviate any problem of the edge of vinyl being lifted by the blade.
    You should of cause leave the application tape on for the pad of the jigsaw to ride on, so as not to mark the surface of the vinyl.
    23 May 2003 at 08:44
    3 bits of good advice there gray..
    i too use app tape over face of vinyl but in most cases if i can.. i put a small outline around the whole peice, leaving it unweeded & also still with app tape applied.
    i then jigsaw. once finished i strip app tape and then the small vinyl outline border that i applied. you will be left with this small but neat white outline all around the whole job. the fact that its there, insures no dog-earing of the vinyl or grit getting caught under the vinyl by the jigsaw blade…
    best of luck!
  • Sparky
    23 May 2003 at 09:32
    Hi Gray,
    Probably missing something obvious here, & I havn’t done much of this sort of work, but on the few i have done, I have sacrificed a few metres of cheap vinyl by cutting the design, using a jigsaw as you suggested, then removing the “template” vinyl & recovering it. Gets around all the problems of the vinyl getting marked.
    Maybe I’m just too enthusiastic about throwing vinyl in the bin 🙄 🙄 🙄
    Just an idea…
    sparky
  • steve
    23 May 2003 at 09:34
    a tip use Bosch A0 jig saw blades for cutting no spelshing of the face very fine cut they are excellent
  • looksteve
    23 May 2003 at 21:08
    quick tip….cover the bottom surface of the jigsaw with masking tape so that it doesnt scratch the surface of the material you are cutting or buy some PTFE stick on tape from a tool supplier like axminster tools for a permanent complete non marking method of using a jigsaw.
    regards to all
    steve
    24 May 2003 at 00:07
    I like Robs solution – cut an extra outline, leave the application tape on – then remove the application tape and extra outline after cutting out the shape.
    I can see that this would work extremely well – Thanks Rob, I’ll use this on the next sign I do like this. Great tip 😀
  • Neil Kelly
    24 May 2003 at 08:45
    Hi Gray I think everyone has coverd the jigging out side but the fomex edges might be long term problem if you want them black.
    I have recently used anew product made by Bret Martin ( they make Forex ) its 10 mm thick and made from recycled material and is has a black cour with a 1mm white face we use it for builders site boards it stops the edges picking up the dirt and looking a mess, If you can get hold of it it might be a permenent edge solution.
  • Neil Kelly
    28 May 2003 at 22:59
    Hi Gray im shure the edges would be fine painted i supose my line of thought was you could have avoided the job with a Black cored Foamalux this is the product I was thinking of not Forex but as you said this may not be available from your local distributers.
    well just an idea.
    neil…..
