Home Forums Sign Making Discussions Gallery Shop Fascia: Rachel Burns
  • Shop Fascia: Rachel Burns
    Posted by David McDonald on 6 September 2006 at 21:38
    Here’s one I finished last Sunday, kept putting it off all last week due to rain but had to get soaked in the end as they wanted to open Monday.
    Hope you like
    Macky
    Dave Bruce replied 19 years, 4 months ago 10 Members · 13 Replies
  • 13 Replies
  • David McDonald
    6 September 2006 at 21:40
    6 September 2006 at 21:41
    nice looking sign macky….cant go wrong with brown and cream very nice 😉
    6 September 2006 at 21:42
    Nice job Macky!
  • David McDonald
    6 September 2006 at 21:44
    Hey – look how tasteful it looked before we started !!
    6 September 2006 at 21:45
    Macky that looks really smart, what is the first (dark) stand off made of 😎 hadn’t seen the second pic, before I posted what a transformation
  • David McDonald
    6 September 2006 at 21:50
    Hi Lynn
    It’s 5mm Forex, wet sprayed chocolate brown on the edges and then flood cated with brown vinyl on the front. On the back are two 10cm wide strips of 10mm thick Forex running the whole length and glued with Fusion + few screws to make sure – although the brown panels are only 5mm they should neve warp.
    Macky
    6 September 2006 at 22:34
    Looks like it’s gone from "shave & a haircut two bits" to high end posh glam!
    Very nice work.
    love….Jill
    6 September 2006 at 22:47
    Macky, that looks very nice,
    But.. I have to ask, why did you use foamwhatever for such a really good overall effect? The sign is not that large, so for just a few quid more, would dibond or perspex been better?
    The time you put into design and build would have not increased the total cost that much more to use better materials?
    I know sometimes, we all have to work to a budget, but I sometimes wonder if we get it right, A good sign, like this, deserves to be made from materials that match the creative skill put into it….
    Not a crit, just a comment
  • John Singh
    6 September 2006 at 22:56
    Looks like a lot of work has gone into this
    Did you have to build away from the guttering or is that shuttering box
    The shop looks so totally transformed
    Well Done!
  • Andrew Boyle
    6 September 2006 at 23:07
    What a difference….looks miles better 😀
  • David McDonald
    7 September 2006 at 07:51
    Hi Peter
    Cash flow is king at the moment as still in that start up phase!! Have to use the materials available in the workshop sometimes – bit like this time then had to over engineer things to ensure they won’t warp etc etc.
    John – yep had to build out the fascia as the sign now runs up in front of the guttering. This took as long as making the actual sign!!! Had to make sure it was striong enough, was water tight etc.
    Thanks for all the comments.
    Macky
  • Jim McManus
    7 September 2006 at 08:06
    Macky,
    Looks really good. Well designed. Would not have looked half as good if it had just been flat vinyl. Something I am guilty of is not using the extra bit of imagination required to achieve great results like this.
    Well done mate.
  • Dave Bruce
    7 September 2006 at 08:15
    Very nice work Macky, looks like alot of work just to get it away from the guttering.
    Well done
