Home Forums Printing Discussions Uniform Printers Service call 0101 on Grenadier SP-1400C!!
  • Service call 0101 on Grenadier SP-1400C!!
    Posted by David Graves on 5 July 2010 at 15:12
    I have been getting a service call 0101 on my printer. I have been told that I need to perform the limit initialization. I have followed the steps given but when i get to cutter down position and press enter I get the message unrecoverable limit sensor. Why is this?
    Gabriel Cristian replied 14 years, 6 months ago 3 Members · 3 Replies
  • John Hughes
    5 July 2010 at 17:23
    When you go thro the setup to recalibrate, be very careful when moving the head to the right – move very gently until you hear a ‘click’.
    If you push too hard the setup doesn’t work.
    john
  • Philip Jeneway
    19 June 2011 at 17:49
    I know this is really old but just had same problem. Answer is when asked for ‘cutter down position’ slowly push cutter to the far left past cutting strip until it’s under the left hand cover, then press enter, the cutting head will slow come back & attach to the print heads & reset it self.
  • Gabriel Cristian
    23 June 2011 at 21:48
    It’s about limit position initialize. Perform that from the limit initialize menu and that should do it.
