Home › Forums › Vinyl Cutter Discussions › General Cutter topics › serial cable
serial cable
Posted by ccmotorsport on 30 November 2003 at 12:22Where would I get a Roland serial cable for this PNC1000.
Alternatively, does anyone know of a pin-out diagram ?
Carl – ccmotorsport.com
ccmotorsport replied 22 years ago 5 Members · 7 Replies -
The cable you require is a standard rs-232c cable you should be able to get from any computer store.
pin connections are.
1 to 1
2 to 3
3 to 2
4 to 6
6 to 4
7 to 7
5&8 to 20
20 to 5&8good luck if you are do the wiring….
Hi new comer, where did you get this info from.
I have wired up a 9 to 26 pin serial cable in the manner you have laid out out it is not communicating with the cutter.
Carl – CCMotorsport.COM
Carl,
I have a Roland PNC 1100 which I believe is a similiar machine to yours and run with a serial cable. I just used one off the shelf from PCWorld or somewhere, never had any problems. Can’t understand why you are getting involved rewiring cables.
By the way what Motorsport are you into because I am a bit of a fan and sometime competitor, I own three Camaro race cars for my sins. I also originally formed and ran (for 10 years) the Racing Saloon Car Cub which in turn runs The Toyo Tyres Modified Saloon Car Championship with the BARC.
Allan
Hi All,
I think the problem you are having with the cable is because the pin outs appear to be for a 25 to 25 pin connector.
Please find below the pin connections for a 9 pin female to a 25 pin male serial cable for a Roland Plotter. (The 9 pin is on the left, 25 pin on the right).
1 & 8 — 20
2 ——– 2
3 ——– 3
4 ——– 5 & 8
5 ——– 7
6 ——– 4
7 ——– 6The default settings for roland plotters are:
9600 baud, 8 data bits, 1 stop bit, no parity, Flow Control Hardware.
I hope this helps.
Best Regards,
Mike Antrum.
Had a problem just as yours but a graphtec 3000 ce, everyone thought cable but in the end it was a conflict with the drivers.
Hope this helps.James
From an old manual Carl.
But Mike is right if you are using 9 pin.
Sorry I Didn’t think to ask. -
We are getting somewhere, now the cutter leaps into action (well as fast as a 14 year old cutter can) and starts cutting.
HOWEVER, just after it has started, the screen displays ‘error 16’ see user manual and the cutter then stops.
Can anyone shed any light on this.
Cheers in advance.
