Activity Feed › Forums › Sign Making Discussions › General Sign Topics › Self Healing Mats
Self Healing Mats
Posted by John.Taggart on February 21, 2011 at 4:25 pmHi All probably not in the right forum but could anyone help with a supplier of self healing mats. Looking for 3 of 2400 x 1200. I don’t know if they come in that size. Thanks
Ian Johnston replied 13 years, 2 months ago 10 Members · 12 Replies -
If you do a search for ‘cutting mats’ there’s a few alternatives.
i’m in favour of 3mm (2440x1220mm) polypropylene sheets.
Hi David
Got those currently but we seem to picking up a lot of crap when we go to laminate vinyl with the static. Also the grooves produced by the constant cutting is a pain.
JAG sign supplies do various mats. even huge table mats.
http://www.jagsignsupplies.com/aqshop/c … .php?id=56 -
I use the 4 x 8 mat from Jag and it is excellent.
Over a year now and it is as good as new.Peter
cherwell also do them, and i think a bit cheaper than jag, but I still prefer glass as a worktop. outlasts cutting mats and nice to put a grid under for cutting square
off cut of Linoleum flooring, upside down, £10 from any flooring supplier, Exactly the same as self healing mats
I’m with Peter, we have two 10′ x 5′ workbenches with safety glass surfaces.
No static, can clean with anything you like, no cutting marks and last forever.
I’ve tried the jag one and didn’t get on very well with it, loads of cutting grooves and it curled like a banana.
Andy
quote Peter Normington:cherwell also do them, and i think a bit cheaper than jag, but I still prefer glass as a worktop. outlasts cutting mats and nice to put a grid under for cutting squarePeter
I have had one of the Cherwell ones for around 3-4 years and its still perfect. Well worth the hundred odd quid. Might try the upside down Lino tho on another bench,….cheers Ian!! 😀
I would have to go with glass after trying all the rest, blades blunt quicker
but the top last longer.Lynn
quote Ian Johnston:off cut of Linoleum flooring, upside down, £10 from any flooring supplier, Exactly the same as self healing mats
:thumbsup: great tip Ian…ill try that
Thanks all. We did have glass in our previous location but we’ve moved to a first floor office and cant get the glass in without spending lots of money. I might give the lino a try before buying the mats as I need three 8 x 4s.
quote Cheryl Smith:quote Ian Johnston:off cut of Linoleum flooring, upside down, £10 from any flooring supplier, Exactly the same as self healing mats
needs to be the proper Linoleum i.e rubbery right through , not the cheap type, with a felt back,
The non slip Variety that is used in schools etc is the best, I’ve only replaced twice in 14 yrs.
