Home Forums Software Discussions Signlab Software scaling strokes problem
  • scaling strokes problem
    Posted by Bob Cuthill on 23 May 2009 at 02:16
    I am using a single stroke font in Signlab called Partoria.
    Its a font we use for routing ultimately, but before we route, I have to show the client a proof first.
    Therefore, as the font is just a black hairline over a dark blue background (difficult to see), I apply a weighty stroke to it with round caps using a light colour. This way the client can see the image as its supposed to look.
    NOW THE PROBLEM PART:
    When I scale the whole proof down (prior to sending a PDF), the artwork and fonts scale down accordingly but the heavy stroke remains. Also if I just export it from Signlab to PDF, its still the same huge strokes making big blobs over my artwork.
    Where am I going wrong?
    James Martin replied 16 years, 6 months ago 5 Members · 6 Replies
  • John Childs
    23 May 2009 at 02:45
    In Illustrator, in the preferences drop down, there is an option to "scale stroke weight"
    Does Signlab have something similar?
  • Bob Cuthill
    23 May 2009 at 02:46
    if there is ….Im not sure where to locate it
  • John Childs
    23 May 2009 at 02:53
    quote BC4 Signs:
    Well, I’m sure a Signlab user will be along later, after the sun comes up, to point you in the right direction. 😀
    23 May 2009 at 06:52
    Weld the outline before scaling down,
    Why do you need to scale it down though? it will export as a pdf no matter what the size
  • Andrew Blackett
    23 May 2009 at 08:46
    quote John Childs:
    In Illustrator, in the preferences drop down, there is an option to “scale stroke weight”
    I’m with John, I was thinking of "scale with object" in corel draw.
    Or as Pete suggests weld it to sort it out.
    Andy
  • James Martin
    23 May 2009 at 13:15
    I always just convert strokes to outlines.
