SC650 Plotter
Hope someone can help on this one as we are out of work without a plotter.
Busy cutting this morning when next colour vinyl i put in mch, switched on & all the lights started flashing. Sometimes this happens if pinch roller not lined up so quickest way normally is to switch off, wait a minute then back on & everything OK, but not this time.
I have checked pinch rollers, checked that both knives in up position (not stuck), switched off at the mains for a while, cleaned optic lenses.Had 2 of these Mutoh SC650 over the 9 years with absolutely no problems, a dream to run until now.
Also got a Mutoh SC1400 plotter that i am having problems with, was sent a patch update for firmware now it won’t work, same day the 650 goes belly up, bl**dy marvelous 2 plotters neither working on same day.
Phoned up Velmex who supplied 1400 says he will ring in the morning to hopefully sought it out. It is just the 650 i need advice on, what to try next!
L J
