Home Forums Sign Making Discussions Vehicle Wrapping Satin Black Vinyl
  • Satin Black Vinyl
    Posted by Chaz Virdee on 7 October 2009 at 11:56
    So I’ve been asked to do my first full wrap in satin black on BMW E30 2DR. The car itself is pretty simple in design, no major contours or recesses.
    Just wanted to know what film you guys recommended for the job. I’ve heard good things about 3M 85 series, is there anything else I should be looking at. Its satin black not matt black I’m after.
    Thanks in advance.
    Chaz Virdee replied 16 years, 2 months ago 4 Members · 4 Replies
  • James Culpin
    7 October 2009 at 15:44
    You may find that you will have a greater choice of materials to select from if you consider a gloss black and laminate it with satin. Whatever you use you’ll want to laminate it to you can handle the material better.
    If no major areas to battle with, look at a black cast from any leading supplier and then get them to also supply a satin cast laminate.
    Hope this helps.
  • Gill Harrison
    7 October 2009 at 17:06
    quote :
    Whatever you use you’ll want to laminate it so you can handle the material better.
    No not the case with the 85 series. It is specifically designed as a car paint replacement vinyl so very user friendly…..spoken as someone who has used it and not just sold it :lol1: ….. It’s 85 micron thick which equates to the same as 3M’s digital wrap vinyl when laminated.
    Gill
  • Malcolm Elliott
    8 October 2009 at 09:26
    Gill supplied me with some of that and it’s working really well, even on the very curvy wings.
  • Chaz Virdee
    8 October 2009 at 11:09
    I spoke to William Smith this morning and there sending out a sample today
