Home Forums Sign Making Discussions File Swapping Sandblasting…
    19 May 2004 at 17:46
    sorry brian may not be whots required the guy is the other side of the window
  • Brian Hays
    19 May 2004 at 17:48
    Can you ask him to come round the other side?!
    19 May 2004 at 17:53
    i asked him but he is to shy then started to mumble something about modeling release forms & fees
  • Henry Barker
    19 May 2004 at 18:05
    I guess you want a silhouette perhaps??
    Here are a couple of pics of me blasting! 🙂
    and here
  • Dave Bruce
    19 May 2004 at 21:34
    Brilliant Henry can I ask what media you use for that?
    I blast steel mostly, occasionally fibreglass boats, but would like to get into sign blasting since I have the gear.
    Any tips appreciated.
    19 May 2004 at 22:24
    can i ask why you fixed the letters to the sign before blasting henry, or is that a daft question.. 😕 just me being nosey. 😉 😆
    also, the darkening of the wood, is that a stain of some sort or have you actualy burned the wood then a clear stain?
    again, just me being nosey mate.. 😉
    em sorry brian.. kinda high-jacked your post mate 😕
  • Henry Barker
    20 May 2004 at 07:27
    Dave,
    I use a fine sand the size here is B7 (silicasand) very dangerous I guess without the right breathing gear. I have 4 tons or had 4 tons in 20kg sacks.
    I have tried Anchor, 3M and Aslan sandblast resist but like Hartco the best, works best in my Summa T series machine, its available in the UK too don’t have the number here at home ( its a bank holiday here today thursday!)
    All my equipment is made by Clemco http://www.clemcoindustries.com, I blast signs with a 6.5mm (1/4″ nozzle). I have an Atlas Copco diesel compressor 2500litres per minute not sure about cfm 🙂
    The project in the pictures was abit unusual, the guy wanted an old looking sign for a diving center,
    I bought new lengths of tanalised timber fixed them together, cut the ends with a jigsaw first, then cut out all the letters in wood, wanted a flat area for them to sit on, and also needed thinner letters so I used them as a stencil I blasted around them, then stained the wood with different stains, then blasted again to make it look more distressed, i then removed the letters as the tops were now damaged from blasting, but put them through the bandsaw like slicing ham so I got a letter half the thickness and damage free, pianted and mounted them and added the rope….sign finished.
