Home Forums Sign Making Discussions General Sign Topics Rounding corners on Dibond
  • Rounding corners on Dibond
    Posted by Paul Munford on 30 November 2007 at 14:56
    Hi All
    I would be interested to find out what different methods are used for rounding the corners on 4mm dibond.
    I know there are various suppliers of corner rounding hand operated machines… are they any good? ……will they put a 25mm radius on 4mm dibond / reynobond.
    Paul.
    David Rogers replied 18 years, 1 month ago 6 Members · 7 Replies
  • 7 Replies
  • Steve Underhill
    30 November 2007 at 15:37
    I have mine CNC machined, but its an expensive way of doing it unless you are on good terms with the owner.
  • Derek Heron
    30 November 2007 at 18:00
    some advice on this thread on corner rounders
    http://www.uksignboards.com/viewtopic.p … highlight=
    Derek
  • Steve Morgan
    30 November 2007 at 18:25
    I use a jigsaw, with care you can cut 3 or four pieces at a time and it’s one less tool to buy, and you can cut any radius you want or come to that any shape panel you want.
    I suppose if I had a lot to do I might buy a dedicated tool but for the odd 8-10 jobs it’s not worth it.
  • David Rogers
    30 November 2007 at 19:01
    Router for me.
    D/S tape circles of 5mm PVC (in the size of your choice) to the corners & use a trimmer (blade with a bearing) to profile them off. Lift of the circles…onto the next sheet.
    Done loads of them like this in 3mm di-bond & 3/4mm aluminium and the results are perfect.
  • Dave Harrison
    A method I use is to cut a guide / template from scrap mdf / ply with the radius required. . clamp this under the panel corner and buzz the router round. . ( edge trim bit – the one with the bearing on ) quick simple and guaranteed perfect corners every time !
  • Paul Munford
    30 November 2007 at 19:54
    Many thanks for the info
    ….seems a router is the preferred way to go!
    Do i need an aluminium cutter or will a standard wood cutter be ok?
  • David Rogers
    30 November 2007 at 20:22
    quote Paul Munford:
    A TC Cutter (Tungsten Carbide) will do fine. AVOID HSS (High Speed Steel) cutters – they are useless!!
    I’ve found TREND are pretty good..and do spare bearings too!
