Home Forums Printing Discussions Roland Printers Roland Xj740 Sheet Cut Assembly
  • Roland Xj740 Sheet Cut Assembly
    Posted by Paul Stenning on 15 January 2018 at 15:40
    I’m after a bit of help with the sheet cut assembly on my Roland XJ740.
    It packed up a while ago and the last time our engineer was in he looked at it just before he was about to walk out the door and told me it was a simple fix, I just needed “a new screw”. Time passed and I’ve completely forgotten what I need to do.
    All the bits were taken off and taped to a piece of scrap dibond so I should have everything except any idea how to reassemble it.
    The spring mechanism is working fine, but I have no idea how the blade engages to stay down to cut.
    Any advice would be greatly appreciated 😀
    Thanks, Paul
    Paul Stenning replied 7 years, 10 months ago 3 Members · 11 Replies
  • 11 Replies
  • Stafford Cox
    16 January 2018 at 17:54
    Does this help?
  • Mat Drake
    19 January 2018 at 13:27
    Hi Paul, The blade engages when part 12 in Stafford’s diagram hits a stopper inside the left panel when the carriage travels to the far left position. It cuts on the return pass and then disengages automatically.
  • Paul Stenning
    22 January 2018 at 08:52
    brilliant, thank you both very much 🙂
  • Paul Stenning
    22 January 2018 at 19:56
    I’ve reassembled it and when the carriage moves over the maintenance cover the cutter hits the stopper, the blade moves down but as soon as the carriage starts moving back towards the right the blade springs back up.
    Video on this link: https://www.youtube.com/watch?v=cq525sXxhlg
    I’m not sure what’s supposed to keep the blade engaged? Before I fixed it back onto the head carriage it was moving freely, but it never ‘locks’ in the engaged position.
    Any idea where I’m going wrong?
    Thanks for any help you can offer 🙂
  • Stafford Cox
    22 January 2018 at 20:36
    Have you run the ‘limit and cutter down position’? Also, if you take the left side maintenance cover off, that will make it retract. Might be a hint?
  • Paul Stenning
    23 January 2018 at 08:21
    I’ve just run ‘limit and cutter position’ but it’s still doing the same thing.
    Not sure what you mean about removing the maintenance cover, or rather why it would help?
    Thanks, Paul
  • Stafford Cox
    23 January 2018 at 09:16
    I’ll try and get a video when I’m in the office later…
  • Stafford Cox
    23 January 2018 at 10:52
    This is what I mean:
    https://www.youtube.com/watch?v=-TOrBfnyCx8
    I know it’s an SP but I’m pretty sure the mechanism on an XJ works in a similar way.
    Stafford
  • Paul Stenning
    23 January 2018 at 12:09
    thanks so much for your patience!
    The blade just isn’t staying down at all, as soon as it moves away from the stopper it springs back up. I’m wondering if I’ve assembled it incorrectly, or there’s something missing.
    If I manually push part 12 on your diagram to the right should the blade stay engaged? Mine doesn’t stay engaged, this is with the carriage over the capping station: https://www.youtube.com/watch?v=MyzDwI9 … e=youtu.be
    Thanks again 🙂
  • Stafford Cox
    23 January 2018 at 12:37
    Sorry Paul, I’m out of the office again and not seeing another Roland for a couple of days. I’ll have a look when I can.
  • Paul Stenning
    23 January 2018 at 12:40
    Thanks 🙂
