Home › Forums › Printing Discussions › Roland Printers › Roland VS-640i DPI
Roland VS-640i DPI
Posted by Daniel Evans on 18 January 2016 at 11:02Hey guys
I’ve now done a few prints with my new printer and so far so good.
I’ve now been asked to produce some labels half the size of a business card but on closer inspection, the dpi is terrible.
I would like to print at a higher resolution but the metamark profiles are only 720dpi.
I’m printing onto Metamark MD-P which states that I should use their MD3 Profile, but the resolution is only 720 x 720dpi
Can I use a different profile or change the resolution?
Hugh Band replied 9 years, 11 months ago 4 Members · 14 Replies -
It’s definitely worth a try. The print heads in those machines are capable of 1440dpi and even 2880dpi IIRC but the limitation is in the solvent ink. I would try using another gloss vinyl profile and see how it looks. What RIP are you using? Versaworks?
Stafford
I’m not entirely certain because I don’t really know Versaworks but there should be some 1440dpi profiles available. Failing that, try downloading a free trial version of any of the other leading RIP’s and see if they do a better job. That way you can be sure you’re getting the best quality from your printer.
Stafford
Daniel
profile issue 720dpi should be perfect for what you are doing chances are you are getting too much ink and that is causing the problem so 1440dpi may actually give you a bigger problem. Are you printing vector or bitmap and what colourKev
Hi Daniel
I do a lot of small labels with tiny print on our VS (about 2mm high) using MD-P and use generic vinyl 2 high quality (1440 x 720dpi) and its very sharp 😀 …and reallly slow.. 🙁 …give it a go, or trial some of the other generics.
All the best
Hugh -
Hi Daniel
For the small text on the metamark P and H vinyl I use high quality on generic vinyl 2, as commented before you have time to get a brew on and do something else while its working though 😀
Did you try this setting on your small text?
Cheers, Hugh -
Hi Hugh
I did try it, it was a better result, I was gonna try and play about with the quality settings tomorrow, just wondered if you used different settings I.e uni directional etc
Also what’s the difference between generic vinyl 2 and the he one?
quote Daniel Evans:just wondered if you used different settings I.e uni directional etc
Not for text based label stuff – could prepare a full english breakfast to go with the brew in the time required! Do quite a bit of colour (not b/w due to the VS inability to handle it 🙁 envy you the vs-i with light black!) stuff for photographers/artists – and very very rarely feel that need to go uni directional. If all printer settings are good then bi-directional on High Quality is good – and they are demanding customers! 😀
But absolutely experiment – its the best way to find out what works with your set up!
Cheers, Hugh. -
quote Daniel Evans:HD one sorry
Sorry Daniel – haven’t got a HD generic AFAIK? Is this one that VSi has and not VS?
Cheers, Hugh
