Home › Forums › Sign Making Discussions › Buy – Sell – Employment › ROLAND VINYL SIGN CUTTER & PLOTTER
Posted by Phil Jenkinson on 30 August 2003 at 08:03Saw this on e-bay,
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? … y=302&rd=1
and wondered what you all think. Would i end up with something i can’t use?
Are there things i should look out for? I run xp would that be a problem?Any pearls of wisdom greatly appreciated.
Phil
Dave Standen replied 22 years, 4 months ago 11 Members · 12 Replies -
XP shouldn’t be a problem Phil, I’d keep an eye on this one Phil, 8 bids in 18 hours, I haven’t a clue on the going rate for 2nd hand plotters but Roland are one of the best, I’d have thought if you get it for a couple of hundred thats not a bad deal if it works if it don’t then getting a Roland engineer out to look at it 😮 then you’d probably be cheaper to buy a new one 😕
I would assume this item does not work and they seller says they don’t know anything about the machine so theres not much point asking questions.
The seller is in sussex and your in manchester it might be an idea if you can get down to view it before placing a bid.
Or if there are any sign makers in sussex who might be willing to go have a look for you.
If you do decide to bid make sure you bid what your willing to pay for a machine that might not work. Just a thought, maybe you could contact roland and see how much it will cost to service the machine to make sure its in working order, if your happy to pay this then contact the seller and tell them you would like to arrange a service see what they say. if they say no then don’t bid as they proberbly know the machine doesn’t work
Good advice all round!
Just looked at website of Sign masterand they seem to have good offers, guess your safe with new or from a dealer or someone in the business.Thanks
Phil
Sounds a bit risky as the seller can’t really vouch for anything
At least if you were buying from a sign guy he’d have it up and running for you to see it
He could tell you more about its history and its performanceAs it is this seller hasn’t a clue himself
This was the first machine I first bought 12 years ago when i first started out. There is not an awfull lot to go wrong with xy plotters and Roland are one of the best. I sold mine after 7 years and it was working as well as when I bought it. The only thing I repalced was the plastic cutting strip.
Roland are also pretty good when it comes to spares as well.The only thing you might be dissapointed with is the speed, it aint quick.
I wouldnt pay over £500 though.
…also you may require some ear plugs. The noise it makes might drive you crazy!
Don’t know on the Camm1 but considering doing a mix on the noises from the PC60, might even become the “Tried and Tested” of the week on Radio 1 😛
Where do you get a new cutting strip and roughly how much do they cost? Can you install them yourself?
quote red dragon:but considering doing a mix on the noises from the PC60, might even become the “Tried and Tested” of the week on Radio 1
LOL!, I totally aggree, noisey bugger of a thing, but lovely prints 🙂
Gav
Bit of a late reply – but:
Also available direct from Roland in Swansea
You can fit yourself – it’s just stuck down with double sided adhesive in the slot it inhabits. Clean all the adhesive out – any bits left will give you a bump on what should be a completely flat cutting surface.
Quick Fix:
Use several strips of celotape along the used cutting strip.
This will bridge the groove you’ve cut and give a new surface!
Doesn’t last long – but it will get a job out!
Regards … Bid D …
