Home Forums Printing Discussions Roland Printers roland versaworks dual buggy
  • roland versaworks dual buggy
    Posted by Shawn Bentley on 17 May 2017 at 08:11
    is anyone using roland versaworks dual ?, I’m finding it so buggy, the previous versa works hardly ever froze or crashed this one just seems to always crash?, any ideas, computer is running ssd drive and up to date etc etc. also it only runs this nothing else on computer files etc. tia p.s also rips so slowly up to previous version.
    Shawn Bentley replied 8 years, 7 months ago 4 Members · 6 Replies
  • Daniel Evans
    17 May 2017 at 09:25
    Hi Shawn
    I don’t see an issue although I’m not really using it as much as others.
    I have got an issue with pre-feeding the media though, I’m currently using the VSi as a vinyl cutter (Media too wide for my graphtec) and it seems to pre-feeding the material to make sure there’s enough?
    Never had this before and can’t find any options for it to stop, great feature but **** me it takes ages.
    Do you get this?
  • Daniel Evans
    17 May 2017 at 10:21
    Worked out . my bug, it’s due to using the print & cut setting.
    Can the cut-only setting be programmed to use heat? I need a little heat as the media is really think and with a little heat it cuts perfectly.
  • Shawn Bentley
    17 May 2017 at 10:43
    hi daniel, I’ve got the print only ej640, only loaded it weekend was so buggy now re installed it through roland download so seems to be bit better although slow ripping up to older version.
  • Davy Stevenson
    19 May 2017 at 19:10
    HI Daniel, There is an option in the machines menu to switch pre-feed on or off. You should find it by pressing "Menu" then selecting "Cutting Menu" then "Pre-feed" Just switch it "off" from here. Not aware of any way to add heat when cutting only. With regards to rip times Versaworks Dual is really slow. What I tend to do is load in a few jobs at a time, print the 1st and while its printing set the others to Rip only. You can do this by selecting your chosen setting then clicking the "cog" icon on the menu bar at the bottom.
    All the best,
    Davy
  • Kevin Mahoney
    20 May 2017 at 19:31
    I’m finding it very slow to rip compared to the previous versions. Just finished a three day & night print session & went through 400 metres of vinyl. Not caught up with sleep yet but job done.
  • Shawn Bentley
    20 May 2017 at 21:32
    I’m same been doing what davy has been doing bringing one in start printing then ripping rest as its printing, also noticed its a lot more prone to crashing than last version.
